Help - Problem w/ Revtek Lift - ABS, VSC, VSC-OFF LIGHTS
Old 05-23-2007, 04:36 PM
clarky_007's Avatar
Exclamation Help - Problem w/ Revtek Lift - ABS, VSC, VSC-OFF LIGHTS
Help! I bought a Revtek 3" suspension lift (part #431) and had it installed professionaly at a shop but now have problems. My 4runner is a 2004 SR5, 2WD. Immediately after the lift was installed, the VSC, VSC OFF, and ABS lights lit up on the dash (no check engine light). They plugged in thier computer reader thing and it said there is a sensor error at the right front tire and a ABS malfunction. The shop checked the sensors but they swear everything is working properly. Anyone else have a similar issue or anyone know what to do.
Already tried disconnecting battery, reseting error, pulling FCU (or whatever it is) fuse.
Please help!
Old 05-23-2007, 09:32 PM
Expat's Avatar
They may not have been careful with the ABS sensor wire when installing your spacers. In this case they probably damaged the wiring. You must be very careful about the ABS wire not to stretch it. I'd almost guarentee you this is what is happening.
Old 05-24-2007, 05:52 AM
LEADfoot's Avatar
i agree
i came with'n seconds of doing that very thing
when i was trying to get clearance for my OME lift
it's way tight in there and hard to notice every detail
Old 05-24-2007, 09:26 AM
mac4runner's Avatar
I agree with the previous two posts. Been there, done that. Replace the ABS sensor wire and your problem will be solved.
Old 05-24-2007, 10:57 AM
clarky_007's Avatar
Thanks for the responses. The sensor is already on order so hopefully that will fix the problem.
Old 08-19-2008, 12:24 PM
coconut's Avatar
any one know how much the abs sensor wire cost????
Old 08-19-2008, 12:25 PM
coconut's Avatar
cost of abs sensor wire??
Old 08-20-2008, 11:07 AM
mac4runner's Avatar
If memory serves, it's about $60.
Old 08-20-2008, 08:39 PM
ksu1998's Avatar
You lower a Lexus or lift a 4runner...same result. Watch those ABS sensor cables...
Old 07-17-2012, 11:36 PM
92yota808's Avatar
i know its an old post rather making a new post, how do you know if the wire is bad?
Old 07-19-2012, 05:44 PM
ARK_SWAMP_RIDER's Avatar
This post does a great job explaining how to check.
http://www.toyota-4runner.org/4th-ge...tml#post771215
Old 08-18-2012, 05:19 AM
DIHOWARD's Avatar
I had a wheel bearing go out and had the same problem, Toyota wants $225 for the sensor, I found one on ebay for $19.99
puddlepirate
07-30-2016 06:29 PM
live4soccer7
05-11-2016 06:52 PM
Firefightersink15
11-23-2015 10:32 PM
Kamaloha
10-16-2015 05:13 PM
shredder4286
10-01-2015 01:09 PM
Quick Reply: Help - Problem w/ Revtek Lift - ABS, VSC, VSC-OFF LIGHTS
