Anyone been able to trick the tire pressure sensors yet ?
Old 01-23-2008, 05:54 AM
nrgetic99's Avatar
My boss has an 08 Tacoma with TPS.
He got aftermarket wheels and they say they could not fit the TPS devices with the new wheels. I am sure I read somewhere of a way to trick the sensors and then have them give off the good signal to turn out the light.
Anywone got any experience ???
Thanks
David
Old 02-20-2008, 10:48 PM
hcetatoy's Avatar
Thanks
David
This does not trick the sensors but does shut off the dash indicator light: http://www.toyotanation.com/forum/t170576.html
Hope this helps...
Old 02-19-2009, 08:40 PM
Shoe1983's Avatar
he could try to use a band sensor, it has a cradle that wraps around the drop center of the wheel, 90% of the time this will work, but sometimes the band can break. I have never ran in the a wheel that i couldnt make the sensor work in her.
Old 02-23-2009, 09:13 PM
sdstud212001's Avatar
strange why couldn't they use the old sensor? was it because they didnt have a rebuild kit or the type of wheel. I put them on aftermarket wheels all the time at my job (Discount Tire Co.)
Old 02-23-2009, 09:22 PM
highridinyota's Avatar
some wheels have the valve hole positioned to where they sensor would be subject to damage during in stall because it is in a position where it cant be installed after the tire.
run into it quite frequently at tire kingdom
Old 02-24-2009, 05:52 AM
ozziesironmanoffroad's Avatar
tpms SUCKS... god i hate sensors. big PITA.
Old 03-07-2009, 11:50 PM
Expat's Avatar
No big drama with TPMS that you want to disable. Just earth out at the module in the passenger kickwell. 10 minute job max.
09-04-2015 09:27 AM
88yodabasket
07-13-2015 01:32 PM
Huntingtruckcletus
07-08-2015 05:26 PM
skoti89
07-08-2015 12:05 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Anyone been able to trick the tire pressure sensors yet ?
