adding a factory E-locker in a non E-locker quipped Tacoma
Old 10-21-2012, 10:21 AM
  #41
westjohns yota's Avatar
ever get the unlocking situation figured out?
Old 10-21-2012, 01:11 PM
  #42
iamsuperbleeder's Avatar
Sure did! My stupid self swapped two wires around when soldering to the relay socket Swapped the wires around, and presto, locks and unlocks like it should! Adjusted the brakes out, bled them one more time just to be certain, and everything is buttoned up and in perfect working order now!
I used trailer wiring for the harness I made; just easier to route the wires when they stick together. After I laid this little schematic out, it was super easy to see my mistake, lol
And a little test video
Old 10-21-2012, 02:06 PM
  #43
HighLux's Avatar
Nice job. I think you are an electrical engineer now!!!
Old 10-21-2012, 03:47 PM
  #44
LOL, far from it; it's a simple circuit, unless you screw it up
Old 10-21-2012, 05:10 PM
  #45
BigBluePile's Avatar
Good job
Old 10-21-2012, 05:20 PM
  #46
Just need some different wheels and tires now... although, with these wheels and tires, I bet I could get off the line FAST on pavement drag racing Prerunner!
Old 10-21-2012, 05:50 PM
  #47
Squuuuuuuuuuueeeeeeelll-BAANG!!!...clunk, clunk, clunk.....
Old 10-21-2012, 06:03 PM
  #48
nah, it's still a Toyota after all
Old 10-21-2012, 06:15 PM
  #49
He he he
Old 10-21-2012, 06:36 PM
  #50
granted, it's not designed for that use, but if it'll take a beating on the rocks, it should handle a pavement launch at least once anyway...
Old 10-21-2012, 07:38 PM
  #51
Lol. At least....once....
Old 10-21-2012, 10:10 PM
  #52
lol, nah I probably wont even use it until I put the new wheels and tires on, BUT, it's one more thing to mark off the list
would LOVE to get a 4x4 in at work that I could strip the driveline from, but I haven't seen a single one in the almost 2 years I've been there... we don't get a lot of 2nd gen Tacomas in, which is why I kind of jumped on this axle when it showed up. but you can bet I'll be keeping my eye out it wont be as cheap though, because I'll be buying all that outright with nothing to give back in return like I'm giving them my original axle this time around...
guess I could just go big and throw a solid axle under it and a divorced transfer case
Old 10-21-2012, 10:24 PM
  #53
SAS tacoma, do it, might as well 3link it right?
Old 10-23-2012, 06:21 PM
  #54
used it today in the parking lot at work... tons of fun, lol
Old 10-23-2012, 06:25 PM
  #55
Lolz
Old 10-23-2013, 11:29 AM
  #56
scott s's Avatar
04 prerunner with no locking diff. I would like to install one , I AM HAVING PROBLEMS FINDING out if i can instll one without replacing cpu..
Old 08-21-2016, 03:29 PM
  #57
Arin Anderson's Avatar
I'm looking to do this swap. I just bought a 2010 Sport 4x4. Still currently own a 2005 Off Road Prerunner with the e locker. Thinking about swapping out the third member instead of the entire axle. Any compatibility issues between these trucks I'm overlooking? Thinking about the ECUs, Trac, and eLSD system since some of that changed from 05 to 10
Old 01-18-2024, 05:06 PM
  #58
jaysix79's Avatar
ever since you done this conversion any issue since you are not running the ECM... like burning out the locking motor or locker acting up?
06-01-2021 01:51 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
makemusic116
08-02-2015 04:40 AM
AaronM
07-08-2015 07:15 PM
Quick Reply: adding a factory E-locker in a non E-locker quipped Tacoma
