yet another 22re idle problem
Old 05-10-2010, 07:23 PM
Dipstik_90's Avatar
I've searched to no end trying on the site but came up empty. I adjust the idle on my truck when it's up to normal temp to 800rpm everything is good. I go out wheeling and even 10min of slow trail riding in low range the idle drops to 400rpm and the truck stalls alot. I'll even turn it off and leave if for a few minutes to scope out the trail and I go to start it, it just starts and stalls unless I have my foot on the gas. I tried to turn the idle up when it's doing this but then when i get back on the road it idles up to 12-1300rpm!!!! I adjusted the TPS, the engine is totally rebuilt with a 270ho cam, it did this before the engine was done aswell. I'm loosing my mind, here my next step is to change the throttle body and the IAC. I was also wondering if there was a way to hook up an idle up solenoid so that when my fan turns on it kicks the idle up a bit to keep it from idling too low as well.
Old 05-10-2010, 08:32 PM
McAtee's Avatar
I have the EXACT same issue, everyone is telling me to replace the catalytic converter
Old 05-11-2010, 05:40 AM
Dipstik_90's Avatar
Well mine kinda doesn't have one anymore so that can be ruled out for me lol.
Old 05-11-2010, 09:03 AM
RustBucket's Avatar
Check that the throttle plate isn't sticking first. Sometimes the little bushings wear out and the plate will close to different locations.
Old 05-11-2010, 09:38 AM
Dipstik_90's Avatar
I'm going to swap TB's tonite and see where that gets me.
Charecter1
11-06-2023 10:08 AM
jbv808
08-06-2021 04:47 PM
Eggslinger
06-08-2019 03:32 PM
steve miller
10-10-2015 01:40 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: yet another 22re idle problem
