WTB door control toyota 85980 - 89101
Old 11-11-2012, 04:51 PM
Luvmy89's Avatar
I am looking for a GEN 1 door control toyota 85980 - 89101.
Old 11-11-2012, 05:22 PM
arlindsay1992's Avatar
Can you post a picture of what you need? Or a description of what it does? There are a lot of little boxes and switches for a lot of different functions. And what year? 1st gen is different depending on whether you mean Pickups or 4Runners.
Old 11-11-2012, 05:58 PM
timothy47129's Avatar
check this out on ebay is this what you are looking for? http://www.ebay.com/itm/Control-modu...-/390262481943.if so the price dont seem too bad to me.
Old 11-12-2012, 06:08 AM
Luvmy89's Avatar
89 4Runner, it is the door control relay that controls all the door function. my front windows have stopped working and all my research tells me this is likely the problem. the post with the ebay link below show a pic of exactly what it looks like with the exception of mine being black and diff part #s. but they are both door control relays.
Old 11-12-2012, 07:17 AM
Luvmy89's Avatar
Old 11-12-2012, 09:27 AM
strykersd's Avatar
I have one for sale for $75. I'm just trying to get back what I spent on it.
https://www.yotatech.com/forums/f109...-relay-258658/
Old 11-12-2012, 10:16 AM
I think that relay only controls the locks. The power for the windows goes through the switch on the door. Chances are the switch is melted. You can either try to repair the switch and install relays to carry the current, or you can replace the switch. I would pull the switch off the door panel and see if it is melted.
Here is an aftermarket replacement:
http://www.ebay.com/itm/1984-1988-To...5ea98a&vxp=mtr
If you find that you want that other box, I have one for $50 shipped.
Old 11-12-2012, 11:52 AM
Luvmy89's Avatar
it is deff the relay not the switch i have checked the switches plus both front windows went out at the same time, in the down position. thanks for the info though
Old 11-12-2012, 12:57 PM
I replied to your PM. I assume you've already checked the fuse?
Old 09-14-2019, 11:13 AM
Yoda_madre's Avatar
You can use a window module by directed 535T and
And a DEI 451m for door locks . My factory module stoped working I haven’t attempted to repair. I’m going to clean and solder new joints but have come up with this solution. I have repaired other vehicles in the past with common issues using theses aftermarket products. I will update info as I get into my finding and thread if I don’t get my oem module repaired .
JAMGarcia
7
07-31-2015 11:46 PM
Luvmy89
11-12-2012 05:34 AM
strykersd
04-17-2011 07:58 PM
cbabywolf02
06-19-2006 05:15 PM
ayoung101
05-02-2004 09:09 PM
Quick Reply: WTB door control toyota 85980 - 89101
