Wobbly Auto Shifter
Old 05-31-2009, 03:02 PM
cdreed06's Avatar
Wobbly Auto Shifter
Hey all, does anyone know offhand what parts I need to fix a wobbly automatic shifter in a 89 pickup? Mine is really loose and I can hold it to the left and then the indicator will line up and show what gear I'm in. I know you can't diagnose from this far away but if anyone has done this before and a cheap fix is out there I would love to know, otherwise I will just keep saying to myself Park-Reverse-Neutral-Now Go. LOL
Old 09-09-2009, 06:14 AM
jmlmarine's Avatar
I have the same problem.
I have had my 90 4runner for about 3 yrs and the shifter has gotten looser and looser since i have had it. I took the assembly apart and cant find anything that is causing it to be loose. I havent had to money to have anyone look at it and fix it but I have gotten a price on a whole new shifter but it is 357.28. I dont want to spend that kind of money when I can just pull it to the left and shift. The only problem that I have is that it is hard to get into part sometimes. As soon as I find some way to fix it cheaper i will let you know.
Old 09-09-2009, 06:27 AM
kellhammer's Avatar
I have the same problem with my 1989 xtracab. I searched the forums and remember discussion about replacing a detent ball gizmo. Apparently, it's only a couple of bucks. But, can't seem to find the thread about it any more.
Old 10-20-2009, 06:56 PM
boxer.fan's Avatar
BUMP !!!!!
I was hopeing the search button would work for this, but I dont see any answers yet so I thought I would bump it up again.
Old 02-11-2013, 04:00 PM
KtrainHurricane's Avatar
Sorry to bring back such an old thread, but this problem was never given a solution and a "search" provided me no answers either... (I am having the same problem)
Old 02-11-2013, 05:58 PM
Co_94_PU's Avatar
Left to right movement is controlled by the pushings and pin at the base of the stick.
Pretty easy to figure out what is worn out one you get eyes on it, if it's not those bushings.
Here is a diagram for the 92(?) models, busing is 33501g and pin is 33511.
Stick is the one in the lower right corner.
Old 01-24-2015, 02:37 AM
SeanCeltiad's Avatar
'03 4Runner automatic shifter loose
hi, I've suddenly got a L to R wobble with my gear shift selector especially 3rd to Drive. I've gotten down to removing everything and can see a SS tension? clip with a hooked end on what I can see, did not see any springs or broken plastic in cavity below and am wondering if someone can tell me before I remove the black plastic "lid" to see where this clip might go is there anything that i will have to be very careful of under that lid piece, it's held on by a shift lever lock pin and shift lever lock nut. Any help would be greatly appreciated asap due to appt at dealership who usually know less than I do thanks to these forums and their members.
Thank you,
CeltiLad
Old 01-24-2015, 01:10 PM
Hrddrvs's Avatar
Look at this.... https://www.yotatech.com/forums/f116...er-fix-267369/
Old 01-24-2015, 04:06 PM
Are you saying that..........
Originally Posted by Hrddrvs
Ok, are you telling me that this has nothing to do with the shift lever guide housing inside the 2003 4Runner and that what needs to be done is underneath it from the outside ?
If so then what is the piece of metal, flat with hooked end that is obviously out of place inside the shift lever guide housing ? And last is the shifter lever doing nothing more than controlling the cable ? which is the reason you sent me to the link re fixing this problem from underneath ?
Thank you for the reply and your help. Hope the pics make it.
SeanCeltiad
Attached Thumbnails Wobbly Auto Shifter-dsc02213.jpg   Wobbly Auto Shifter-dsc02212.jpg
Old 01-24-2015, 06:14 PM
Hrddrvs's Avatar
I did'nt realize you need info on a 2003.The link I posted is for 86-95 trucks and 4runners.Try the 4th and 5th generation trucks and 4runners forum on this site.Best of luck.
an1mal_69
09-08-2015 09:40 AM
djpg2000
09-07-2015 10:36 AM
May-39
09-06-2015 01:05 PM
eggens
09-05-2015 12:16 AM
Quick Reply: Wobbly Auto Shifter
