will a window regulator from a manual crank truck work on a truck with power windows
Old 08-28-2011, 11:20 PM
gary96360's Avatar
my trucks window regulator is stripped and i was wondering if one from a manual crank truck work in mine. thanks
Old 08-29-2011, 05:49 AM
bamacj5's Avatar
it should, it just wont be power, and you might have to put a hole in your door panel for the crank
Old 08-29-2011, 10:59 AM
gary96360's Avatar
im pretty sure the crank part unbolts from the regulator and the motor just bolts in
Old 08-29-2011, 12:40 PM
91muddog's Avatar
it kinda looks like it does, just went and pulled my door panel to check, i need to replace my manual regulator anyways. anyone have a pic of one out of the truck??
im going to picknpull tomorrow, ill probably get one so ill get some pics for you for sure!!
Old 09-16-2011, 08:06 PM
gary96360's Avatar
91 muddog, did you change it?
Old 09-18-2011, 03:45 AM
nmtoy's Avatar
It will work. I swapped my power window regulators and door panels for manual ones on my 86 4runner a few years back.
The hardest part was finding manual door panels in good condition.
Robb
Old 09-18-2011, 08:00 AM
4banginRunner's Avatar
Yes it will work, I have a power window in my drivers side and a manual in the pass side of my 4Runner right now...came factory power windows.
Old 09-19-2011, 08:37 AM
gary96360's Avatar
4banginrunner i still want the power window function. i just wondered if the power window motor can be bolted onto the regulator. i think the manual crank unbolts off the regulator
toy89yota
06-24-2015 01:18 PM
saphirekosmos
06-22-2015 10:26 AM
gog1968
06-22-2015 05:55 AM
streetuner15
06-18-2015 10:59 PM
Quick Reply: will a window regulator from a manual crank truck work on a truck with power windows
