Will a newer model cab fit on a 1986 hilux?
Old 01-28-2012, 04:57 PM
Gilly2011's Avatar
Hey guys I'm getting a Toyota hilux soon and the cab is wrecked and was wondering if a newer model cab would fit on with out any hassles and would you have to change the body mounts
Old 01-28-2012, 05:06 PM
toyota4x4907's Avatar
How much newer?
Old 01-28-2012, 05:10 PM
wmayota's Avatar
87-88
Old 01-28-2012, 05:14 PM
Gilly2011's Avatar
Around 1989-1990s
Old 01-28-2012, 05:18 PM
'87-'88 will work. Not sure about '89-'95. Dont think so without moving some things around.
Old 01-28-2012, 05:21 PM
wmayota's Avatar
Both gens. use the same frame don't they? Worse comes to worse maybe you would have to fab some new cab mounts...
Old 01-28-2012, 06:03 PM
Gilly2011's Avatar
Yer that's not to bad I just wonder if the engine will fit fine it probably will
Old 01-28-2012, 11:07 PM
Gilly2011's Avatar
also i have never been able to under stand the diff gears what gears would i need to run 35s?
Old 01-29-2012, 06:00 AM
MudHippy's Avatar
The cab mounting points are in the same place on all 84-95 PU frames(2WD & 4WD). Meaning, you can put any cab from those years on any frame from those years.
Old 07-19-2013, 07:56 PM
Jordan Avramovic's Avatar
so does this mean a 91 cab can fit an 85 chassis
rondogracing
07-14-2015 07:00 PM
rbh261
07-13-2015 12:04 PM
hexrain
07-12-2015 01:13 PM
garagespace
07-09-2015 08:37 AM
Cplmike
07-08-2015 08:47 PM
Quick Reply: Will a newer model cab fit on a 1986 hilux?
