Will an 04 Tacoma rear bumper fit a 93 pickup?
Old 04-23-2013, 04:32 AM
phild111's Avatar
Hello all,
Is there a way to fit an 04 Tacoma OEM rear bumper to a 1993 Toyota pickup? I mean if I use the 1993 mounting brackets?
Old 04-23-2013, 09:44 AM
Co_94_PU's Avatar
I know you can interchange some of the newer beds, but I don't recall anyone mentioning any modifications needed. This leads me to believe the frame rails are maybe the same spread. So yeah maybe. Try it and post back results?
Old 04-23-2013, 11:10 AM
wyoming9's Avatar
Red face
You can do pretty much anything weather it will be cost effective or look good one never knows.
If you attach the bumper to your brackets either make adapters drill holes or just weld them on.
I am pretty sure the brackets are different.
Old 04-23-2013, 04:11 PM
phild111's Avatar
Thank You Co 94 PU and Wyoming9. I guess I should have asked if the '04 rear bumper would be a direct fit to the '93 chassis. I heard I could use the '93 brackets and attach them to the '04 bumper. Wyoming's right, anything can pretty much be done. For example, I fit the stock '06 Tacoma steel rims on my '93. I had to have the hub diameter machined larger. I cannot fit the factory '06 center cap on, but they look great anyway. I commited and bought the used '04 bumper. I'll post the results when I get a chance to get to it.
Thanks again!
dirtrider0129
10
06-24-2015 12:24 PM
Robinhood150
07-09-2002 07:54 AM
westbound
06-07-2002 03:30 PM
Quick Reply: Will an 04 Tacoma rear bumper fit a 93 pickup?
