why is my 22re so loud?
Old 12-11-2008, 06:12 AM
thez71kid454's Avatar
I have a 86 pickup 4wd with a 22re. When i bought the truck it had 264,000 miles on it, but the engine was supposed to be rebuilt, at idle the fan seems to be really loud and so does the engine, the engine has a nosie as if some bearings are loose, im not really sure. any help to cure this problem?
Old 12-11-2008, 06:13 AM
jsn_stockard's Avatar
Prob the valve lash if it is a rattle up top
Old 12-11-2008, 06:35 AM
Flash319's Avatar
Your fan clutch is NG. The fan should be turning slow. At first start up it will pump air for about 30 sec then the clutch should let go. The other rattle could be lots of things. Most likely timing chain tensioner problem.
Old 12-11-2008, 06:59 AM
MMA_Alex's Avatar
Mines just naturally loud. The top end clicking "diesel noise" is the valve lash. I've done the valves a number of times, and it does get a little better when they're adjusted right. I also replaced the adjuster studs, and they were worn, and its quieter now, but still noisy, especially compared to cars that are build today
Old 12-11-2008, 04:32 PM
abecedarian's Avatar
I agree that likely the fan clutch is not operating properly.
also on a high mileage engine, it's possible that the rocker arm shafts are worn and no amount of adjusting the valves is going to make it go away.
Old 12-12-2008, 01:38 PM
well ill see what i can do, i appreciate all the help
voiddweller
05-20-2021 07:58 AM
JNapolitano
11-14-2019 07:46 PM
jashoeuh
11-26-2017 07:01 AM
Team420
12-30-2015 01:31 PM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: why is my 22re so loud?
