why does my 4runner sputter in low rpm
Old 11-16-2007, 02:44 PM
bigt's Avatar
hard starting and sputtering in low rpm.. changed the plugs to bosch plat. problem solved for 3 weeks now its happening again and the plugs def look used.. gonna use the ngk plugs and do an oil change.. i just seafoamed...., engine was rebuilt 2 years ago.
the fuel filter i have but it looks like a really hard spot to get at with my stubby finger.
Old 11-16-2007, 02:54 PM
ozziesironmanoffroad's Avatar
that may be the reason... these engines dont seem to like platinum too much... try going to a lighter grade of oil if using something heavy, and check your fuel pressure. maybe your fuel pump is going out
Old 11-16-2007, 03:11 PM
bigt's Avatar
how would i check the fuel pressure??? do i need a gauge??? i also have a parts truck that was running great when i was side swiped by 2 deer..would it be easier to change the whole tank or is the fuel pump not in the tank on these trucks?
Old 11-16-2007, 03:12 PM
is there a service port on the fuel rail? if so check the pressure of it.
Old 11-16-2007, 03:59 PM
bigt's Avatar
yeah there is probably a port... but what kind of a gauge?? just a normal air gauge or is there a fuel gauge?
Charecter1
11-06-2023 10:08 AM
icentropy
09-16-2020 02:47 PM
MTLroadierunner
07-15-2015 12:58 PM
musashi86
California SoCal
07-07-2015 03:31 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: why does my 4runner sputter in low rpm
