Whining sound
Whining sound
I have been driving lately and i got a whining sound in my engine. I am not sure where it is comming from but it only happens when i press on the gas pedal. Can anyone please help and tell me what this sound is and can i still drive with it.
Originally Posted by superjoe83
i would check you power steering fluid level
i just want to make sure its 100% positive it's coming from the engine compartment. i had a whining sound for the longest time when i first got my truck, i thought something was seriuosly wrong, it changed with engine speed. it turned out to be my stereo making the sound, alternator whine.
which engine do you have? if it is the 22RE (4cyl), it could be the power steering tensioner bearing. they have been known to go bad and make all kinds of horrible sounds.
if you go to toyota, they will tell you (or at least three different dealers told me) you have to buy the whole assembly for like $100, but you can actually just buy the bearing for less than $10 (got mine at a local bearing shop called "Applied Technologies, Inc.", but i think napa might carry them).
the bearing number is: SKF 6204-RSJ, NSK 6204V, or equivalent
takes about 20 minutes to replace it.
(btw, to test, just take off the power steering belt and run the engine...see if the whine is still there. if not, it's most likely that bearing...though it could be the power steering pump, too.)
i had a strange and annoying whining sound once that was coming from somewhere inside back when i had my camry. it took me awhile to figure out the origin of it. it turns out that it was coming from about 2 feet to the right of the driver's seat and only happened when my ex-girlfriend was in the car with me. well, needless to say, problem solved. no more whining, not even when i sold it at 220k.
could be the fan clutch also...they whine sometimes...strangely enough, when they are working properly.
(my truck had a bad one when i got it...the bad one never made any noise, but i would overheat crawling up steep hills. put on a new fan clutch and the overheating was solved, but, dang, that thing can whine like a bi...um...er, well let's just say it can be pretty loud when it engages.)
The timing belt idler bushings make a lot of noise when they get old. I replaced mine for that reason when I changed my timing belt the time before last. Make sure it's not your belts making all that racket. My belts have been known to make all sorts of noise. Belt dressing spray takes care of that.
My truck whines a little from behind the timing cover (sounds kinda cool actually) I figure I got the timing belt just a bit tight when I changed it last. I been meaning to pull it apart and back it off a bit but I haven't yet. The only other parts of interest back there are idlers and a water pump?
zytra
01-24-2019 03:16 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
