Whining radiator and above average temperature.
Old 01-04-2014, 12:30 PM
SqWADoosh's Avatar
So my good ol' 88 has a new problem for me to figure out. She has a radiator whine after driving (or idling) for 10-15 mins. Also the temperature has raised from where it normally sits. There is a smell of antifreeze that I'm pretty sure is coming out of the bleed tube attached to the overflow tank. I haven't drove it for an extended amount of time to see if it completely overheats due to being scared of it getting stranded. The only work I've done on it recently is change out my CAT and an oil change. Any ideas guys on where I should start on diagnosis? She has a 22re. Thanks fellas as always.
Old 01-04-2014, 12:39 PM
ksti's Avatar
Check that radiator cap, could be the culprit.
SqWADoosh's Avatar
Should I just replace it and see if it fixes my issue? I mean its cheap right. I'll start with that. Thanks. Anybody else?
Old 01-04-2014, 01:44 PM
Blueman's Avatar
Yes, I'd just replace the cap for your initial debugging:
Amazon.com: Stant 10227 Radiator Cap - 13 PSI: Automotive Amazon.com: Stant 10227 Radiator Cap - 13 PSI: Automotive
Mine original cap wasn't leaking, but it wasn't holding pressure, and yours might just be tired and ready for renewal, especially if it's still original.
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
mreagen
10-05-2015 04:27 PM
scott90
10-04-2015 09:21 AM
Matthew Perez
09-28-2015 05:43 PM
Quick Reply: Whining radiator and above average temperature.
