Whining noise when I turn off engine
Old 10-11-2007, 12:49 PM
co4rnr's Avatar
When I turn off my 87 4Runner with the 22RE, it makes a whining noise. I noticed that it started doing this after I switched over to Mobil-1 Synthetic. Any ideas?
Old 10-11-2007, 01:46 PM
co4rnr's Avatar
Does anyone think this is related to switching oils?
Old 10-11-2007, 01:51 PM
MRecio's Avatar
I dont think the kind of oil would do it only thing i can think of is the weight of the oil... is it thicker or thinner then what you used before? could be it... but it just doesnt seem like it... can u be more specific on where this noise is coming from?
Old 10-11-2007, 01:58 PM
co4rnr's Avatar
The oil weight I am running is the same as before. Just now I am running synthetic. I am not sure where the noise is coming from. All I can hear is that when I turn off the engine, it makes a whirring noise. Like something is not shutting down smoothly.
Could it be related to the valves?
Old 10-11-2007, 03:13 PM
co4rnr's Avatar
bump.
Old 10-12-2007, 12:56 PM
n4ynu1010's Avatar
Whinning Noise
Have you tried looking at fan or fan clutch maybe ???
Not sure unless it is a tiny vacumn leak bleeding off -they can sound funny sometimes .
Can't imagine a oil change messing up something , I run all synthetic myself and can't imagine what could be turning a little after shut off unless the fan , maybe you got a leaf or stick in your shroud hehe .
Old 10-12-2007, 01:39 PM
co4rnr's Avatar
What you said got me thinking. Maybe my timing is off a little. On my last truck when my timing was not right it would diesel a little after I shut it off. It does not act like it is shutting down smoothly.
Old 04-04-2009, 05:50 AM
BigBuick's Avatar
See i have the same thing going on right now with my 301... i just swaped out the distributor and all that fun stuff. But i also put in the same type of oil... now when i turn on my car the RPMs go way up, i hear the whine, and when all power is cut something is whineing down... Im wondering could it be something like my oil pump?
Old 04-04-2009, 07:51 AM
nv4runner's Avatar
An electric fan will also whine down after you shut off the engine. Running your A/C? The condenser fan might be the sound you hear.
Old 04-04-2009, 07:56 AM
BigBuick's Avatar
totaly a timeing issue guys... the fan sure if its a little whine but i think were tlking about something thats scarey loud... i just fooled around with my own timeing and that sound is longgggggg gone... everythings working fine now no out of the ordinary sounds... i sigest doing the same if ur having this problem aswell.
Old 04-04-2009, 10:42 AM
desert-rat660's Avatar
ive had bad luck running synthetic oil in an engine that hadnt been ran with it since it was new. the crank seals started leaking an the oil pressure was low.
mskalmus
05-28-2017 07:51 AM
Kalihi,HI
07-09-2015 04:29 PM
God's Bounty Hunter
07-08-2015 12:54 PM
MTLroadierunner
07-06-2015 12:17 PM
karbin
07-05-2015 11:37 PM
Quick Reply: Whining noise when I turn off engine
