whining/ grinding noise in front end
Old 12-28-2011, 04:13 PM
xxyotaxx13's Avatar
Hey guys I own a 92' Toyota pickup and to cut right to the Chase it has a grinding / whining noise in the front end when its moving and when I go to slow down to stop there's a thump in the front end ....also there is a ticking coming from the dash and my cousin noticed that my front drive shaft is always moving so he thinks that the hubs might be stuck and it keeps trying to switch from 4wd back to 2wd , could that be the ticking or grinding noise?
Old 12-28-2011, 05:57 PM
92dlxman's Avatar
manual hubs? 4cyl or 6cyl? auto or manual?
Old 12-31-2011, 12:32 AM
xxyotaxx13's Avatar
No auto hubs, 6 cyl manual
Old 12-31-2011, 01:39 AM
fork's Avatar
no auto hubs as in, they are manual? or no, as in, they are automatic?
Old 01-01-2012, 11:31 PM
xxyotaxx13's Avatar
Sorry there automatic
Old 01-01-2012, 11:33 PM
xxyotaxx13's Avatar
Yea the sounds went away for a bit but just recently came back and got worse so I took it off the road hoping I can fix it
Old 01-02-2012, 05:39 AM
waskillywabbit's Avatar
92 pickup does not have automatic hubs.
If you don't have manual hubs you have drive flanges on a ADD system.
Pretty simple to see if your front dshaft is turning in 2WD. Go slow and have someone look.
:wabbit2:
Old 01-02-2012, 09:23 AM
xxyotaxx13's Avatar
Oh ok I didn't know that and yes my front drive shaft does turn when I'm moving in 2wd
Old 01-08-2012, 07:18 PM
99blackSE's Avatar
I'm getting the same noise too nowadays, not sure what it is either. I think I'm going to try greasing the zerks on the front shaft when I get home but maybe the u joints are shot anyways...
Old 01-10-2012, 05:47 PM
xxyotaxx13's Avatar
i changed one of my u-joints not too long ago but let me know if it works
Old 01-12-2012, 08:10 PM
99blackSE's Avatar
Well it looks like it may have been the front diff as it appears to be shot now; no 4WD.
Old 01-12-2012, 09:31 PM
92Yoda's Avatar
I have this exact problem, very sporatic, but only when cold, i have no idea what it is but it sounds like the sane problem, i also have auto hubs
Old 01-13-2012, 08:34 AM
gb42's Avatar
My 92 runner does this also, but only when it is cold outside and only after i turn to the right pretty sharply.
Old 01-13-2012, 08:19 PM
shaeff's Avatar
Lube the spindles?
09-04-2015 09:27 AM
Daneums
08-20-2015 05:36 AM
mengquis
07-13-2015 10:39 AM
razorman8669
07-12-2015 12:13 PM
Jonny246
07-12-2015 04:51 AM
Quick Reply: whining/ grinding noise in front end
