Whats Wrong With My Motor!!!
Old 05-30-2006, 07:57 PM
AH64ID's Avatar
cool, its a good place to fly...
Old 05-30-2006, 07:58 PM
AH64ID's Avatar
so, its set... Gonna have AAA tow it to Toyota, at least for a diagnosis...
Old 05-30-2006, 08:06 PM
Chuki's Avatar
Have you ran a compression check on it?
Old 05-31-2006, 01:06 AM
ovrrdrive's Avatar
What he said... That's where I'd start. That will answer if it's a HG.
Old 05-31-2006, 04:46 AM
  #25
AH64ID's Avatar
No compression check, I dont have the tools. Its going to the dealer this am, and hopefully they can diagnose it.
If its major it will probally wait until next year to get fixed as I am leaving for 10 months.
Old 05-31-2006, 05:58 AM
  #26
4Hummer's Avatar
Sounds like bottom end to me... Thats almost the same "Clack Clack Clack" Noise I got.
A compression tester is only a couple bucks, screw it into the spark plug hole, remove coil wire and crank the engine over. Take a reading from each pistion and compare.
Old 05-31-2006, 06:54 AM
  #27
AH64ID's Avatar
The rig got dropped of at toyota this am. Hopefully they can fit it into the schedule today.
The big things are the clank, only under load.
cylinders 3&4 are firing but only at maybe 10% power
coolant is 10 days old and cloudy
burn 20 second puff of oil after extended idle, 5-15 minutes
not appearing to me loosing/making coolant or oil
Old 05-31-2006, 07:40 AM
  #28
Buck01's Avatar
let us know what they find out.
Old 06-01-2006, 10:21 AM
  #29
AH64ID's Avatar
Looks like its probally a blown HG: Compression is 170-150-25-20
Probally blown between 3 and 4.
Not sure if I will have the stealership fix it, or wait until I get back from Afghanistan. The only reason I would fix it was so my wife had a spare rig. The engine wont really be hurt if it sits for 10 months. And if I do the work I can spend tons less and have the injectors cleaned, plenum cleaned...etc...
Old 06-01-2006, 10:28 AM
  #30
Buck01's Avatar
If you have the know how to do the work then go for it. When you get back of course : )
Old 06-01-2006, 11:09 AM
  #31
Chuki's Avatar
If your going to let it sit, I would drain all the water out of it, every little bit of water you can, change the oil, run the rig for a little bit to get the new oil all over everything. That way you don't have water mixed with the oil or sittin on your pistons, you leave that sit for to long and it'll be a full rebuild when you get back.
Old 06-01-2006, 11:35 AM
  #32
AH64ID's Avatar
That was my plan... No need to rebuild the whole thingm, at 160K its almost new :-)
Old 06-01-2006, 11:39 AM
  #33
snap-on's Avatar
or have a buddy do it while your gone. im shure theres more than one yota techie willing to take it on and geterdone
Old 06-01-2006, 11:41 AM
  #34
Buck01's Avatar
would have to have alot of faith in a buddy to let them work on your truck when you are not there.
Old 06-01-2006, 12:03 PM
  #35
BT17R's Avatar
Originally Posted by AH64ID
...and no loaner on the 03, just a rental...which I will be getting.
Assuming your Runner has less than 50K miles, any Toyota dealer is obligated to give you a free loaner if your truck needs a driveline warranty repair. Same for the bumper-to-bumper 3/36 portion, but you might be beyond that so the 60/50 driveline warranty applies. See your Warranty Guide for details, it stays with the truck and all eventual owners.
Old 06-01-2006, 01:11 PM
  #36
AH64ID's Avatar
Yeah, it never got to the point where it was necessary. The runner, suppossedly, had a little carbon in one of the cylinders.. Once it got hot it burned it out. No charge. guess I'll seafoam it :-)
Old 06-01-2006, 02:17 PM
  #37
BT17R's Avatar
Any chance you've run something other than the OEM paper air filter?
Old 06-01-2006, 02:34 PM
  #38
AH64ID's Avatar
Nope, has an OEM in it.
cars-guy
08-16-2020 06:59 AM
okamikai
04-30-2018 10:19 PM
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
msane99
07-17-2015 10:13 AM
Quick Reply: Whats Wrong With My Motor!!!
