what's this hose (heater hose?)
'91 3.0 v6 pickup
this hose is bulging and had to be tightened down yesterday after it was leaking.
I need to replace but seem can't find the part (heater hose?) online that matches these curves except for the HPS silicone one. Is it no longer available in rubber?
I know very little about this stuff so please be kind!
circled in blue
circled in blue
The following users liked this post:
oilcooler (01-02-2024)
Welcome to YotaTech.
Should be 87245-35040.
https://www.yotashop.com/heater-hose...5-87245-35040/
https://parts.lakelandtoyota.com/p/_...724535040.html
If you order it, be sure to have your VIN handy; Lakeland hints that the part number may depend on body style.
Be very careful when you go to replace it I was trying to take mine off in one piece because I did the 5vz swap and I needed to figure out which hose I wanted to use and I ended smashing the heater core tube a little and I couldn’t get the hose to seal for a while. I recommend just slicing the middle of the hose with a knife
i'm also looking for that heater hose for my 90 4runner with the 3vze engine, but that 87245-35040 heater hose is for the 1992-1995 models with the 3vze. that hose is shorter and different compared to the 90-91 models. does anyone know the part number to the 90-91 heater hose? i can't find it as well.
