What transmission do I have? solenoids?
Old 10-24-2009, 09:18 AM
benstruck's Avatar
Hello,
I have a 1991 4runner V6 4wd auto, i ordered some solenoids for the transmission but they do not appear to be the same ones on my vehicle. They mount the same but electrical connection is oriented in diff direction and they are smaller. How can I confirm which transmission I have and which solenoids I need?
Thanks for help
Old 10-24-2009, 04:28 PM
benstruck's Avatar
anyone?
Old 10-24-2009, 04:37 PM
Shawn6string's Avatar
Tag on the fire wall should tell you. At the bottom of it shoul be ...paint code/trimcode/gear code/tranny code. I bet it is a (a340?) f or h... Cant remember
Old 10-24-2009, 04:47 PM
https://www.yotatech.com/wiki/index.php/Main_Page
...check out the wiki page...lots of info
i looked it up ,its a a340h..
Here a few sites for the right solenoids..or do a search on a340h solenoids and see what you come up with.
http://www.bulkpart.com/Merchant2/me...e=A340solenoid
http://www.makcotransmissionparts.com/A340.html
https://www.wittrans.com/showfilter....49&Section=128
Old 10-24-2009, 05:30 PM
buckz6319's Avatar
these are the solenoids I took out of a donor A340H,,,,,take a look and see if they look like the ones you received?...the black one came from the hydraulic transfer case that I tore down last summer
A340H all torn down even the hydraulic transfer case
Old 10-25-2009, 08:30 AM
benstruck's Avatar
Thanks guys, yes those are definitely the same as the solenoids in mine. I was curious because the replacement ones have a ground wire and different electrical connection, but I assume that wouldnt affect anything.
I ordered the ones for A340E and they appear to be slightly different, does anyone know if these will work? these are the ones i had ordered:
http://www.transmissionpartsusa.com/...-00094393a.htm
Old 10-25-2009, 09:33 AM
bugs1961's Avatar
This site gives you the correct Toyota part number for any part on the truck: http://www.toyodiy.com/parts/ Put in your VIN and only parts for your particular engine/transmission combination will show.
Old 10-25-2009, 11:17 AM
buckz6319's Avatar
I can't answer that question.....but if you need the solenoids I have in the picture make me an offer.....good luck!
Old 10-26-2009, 05:59 AM
benstruck's Avatar
The ones I had ordered worked perfectly!! tho they looked nothing alike, thanks for the help guys!! Its driving perfect now!!
pickle6415
10-19-2015 08:08 AM
ToyotaMD
09-22-2015 06:28 AM
briholt
09-20-2015 10:26 PM
TransAmBandit
09-20-2015 06:08 PM
kelly1450
09-02-2015 12:29 PM
Quick Reply: What transmission do I have? solenoids?
