what tranny do i have?
Old 01-08-2008, 09:55 AM
gbalias's Avatar
where are the identifying marks for the trans? im about to service it and wanted to be sure i was looking at the correct specs.
i have a 88 p/u 22re 4x4 manual trans.
thanks!
Old 01-08-2008, 11:33 AM
Matt16's Avatar
Go to your truck, open the door and on the sill, by the door, there is the manufacturer's info. At the bottom right corner, it will say W56 or G58. Thats your transmission. If you have ADD, then from what I've heard, its probably that you have a G58.
Old 01-08-2008, 03:02 PM
gbalias's Avatar
its not there. the info plate only has mfg date, VIN, vehicle weight info, and wheel/tire info. no documentation on tranny information on there.
is it not stamped on the trans case somewhere?
Old 01-08-2008, 03:04 PM
4Crawler's Avatar
It is there on my '85:
- http://www.4crawler.com/4x4/ToyVIN.shtml
Old 01-08-2008, 03:39 PM
TORTIS's Avatar
W56 transmission, unless somebody swapped a different one in there.
Old 01-08-2008, 04:11 PM
Elvota's Avatar
This link has some good info as well:
Click me:
Old 01-09-2008, 11:12 AM
gbalias's Avatar
w56 is what i think it is. but the info plate looks nothing like the pics posted....heres mine:
Old 01-09-2008, 01:15 PM
Staff
DeathCougar's Avatar
No.
84-88 Truck and 84-89 4Runner EFI used a W56 transmission. Easiest way to identify an 84-88 W56 is the top shift plate. It will have 6 bolts holding it down, and 4 bolts holding the actual shifter to the shift plate.
You need to look under the hood to get the correct info plate.
Old 01-09-2008, 01:32 PM
Staff
"On the passenger cars, trucks, and landcruisers the ID plate is located on or adjacent to the firewall within the engine compartment."
Old 01-09-2008, 04:37 PM
gbalias's Avatar
w56 it is. thanks guys. thats what i figured but wanted to be 110% since im about to service it.
i also need to do my rear main.
ladybugRC
458
08-21-2020 10:41 AM
TheBFA
02-15-2020 06:55 AM
live4soccer7
05-11-2016 06:52 PM
Davebarbier
11-03-2015 03:28 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: what tranny do i have?
