What size are the front bumper bolts??
Old 01-30-2012, 03:57 PM
dntsdad's Avatar
I have to order these bolts to install a new bumper and I am not in a postition to go out to the truck and look. I only have internet pictures to looks at.
Anyone know the right size bolts that go in the mounting location for the bumper in this picture as mine is similar?
The bottom ones along the crossmember. Looks like a total of 6
Old 01-30-2012, 06:14 PM
rattlewagon's Avatar
What kind of bumper? Unless you added the 2 top ones with a frame brace (recommended) your 92 only has the 4 lower bolt holes...
Most aftermarket bumpers for 3rd gens also have 2 holes on each side by the body mount for side support.
Old 01-30-2012, 06:27 PM
waskillywabbit's Avatar
You can order them from the dealer cheap. IIRC those are M12 and M10 x 1.25
:wabbit2:
Old 01-30-2012, 06:57 PM
cman1's Avatar
stock bumper only has 4,two on each side.12mm.just swapped my bumper saturday.
Old 01-30-2012, 07:08 PM
SCToy's Avatar
M12x1.25 for the 4 across the front crossmember.
Old 01-30-2012, 07:32 PM
dntsdad's Avatar
Striking out finding any online. Any ideas?
Old 01-30-2012, 08:33 PM
cman1's Avatar
any 12mm bolts with locknuts and washers will work.
Old 01-30-2012, 10:43 PM
wyoming9's Avatar
Red face
Pointe Products has JIS bolts.( Japanese Industrial Standards) A search for JIS bolts will turn up quite a few vendors.
Also the hardware from the dealer as Wabbit said is not expensive!!
Old 01-30-2012, 10:51 PM
justin_4runner's Avatar
u can also go to ur local auto parts store and get some grade 8 bolts that will work too...
Old 01-31-2012, 05:13 AM
Those threads often get gunked up from lack of use as do any 20 year old threads.
New bolts from the dealer and chase a metric tap through there with some lubricant and it makes things go together SO much easier. A little extra effort but well worth it if you are going to keep the vehicle for the duration.
You want 10.9 grade bolts. McMaster Carr has them but the dealer can order them too easily.
:wabbit2:
Old 11-25-2018, 07:43 PM
KHK
KHK's Avatar
Bumpe
a little late to this thread, but does anyone know if this is a custom bumper ? Or who makes it ?
Old 11-25-2018, 11:40 PM
ev13wt's Avatar
You make it. Welder, bender, have fun!
lledwod
08-30-2016 01:03 PM
shisha1999
03-16-2016 12:25 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: What size are the front bumper bolts??
