What? Loose shifter
Old 07-22-2007, 03:46 PM
Kaydon's Avatar
What? Loose shifter
My shifter is a little bit loose, and will sometimes turn to the right or left. I can't even get into 5th gear due to it. 1st, 2nd, 3rd, 4th & reverse are fine, 5th is a PITA.
Any ideas?
'92 p/u 22re, if that helps, lol.
Old 07-22-2007, 03:51 PM
MudHippy's Avatar
If it ain't your shifter seat needing replaced I'll be suprised. It fixed mine from doin' that.
Buy the best one on the market here:http://www.marlincrawler.com/htm/tra...rans_parts.htm get the socket too, it's worth the price.
Old 07-22-2007, 03:53 PM
84sr5yoty's Avatar
Yep, I agree with mudhippy
Shift lever pilot bushing # 33548-31010 (green)=$7 CDN
Shift lever seat # 33505-35020 or 33505-35030 (white)=$16 CDN
Note: the 2 above #?s fit all trannies:G,R,W series (22R,R-E,3VZE)84-95.5,no need for entire shift lever retainer (85-95.5 pre-Tacoma)
http://www.4runners.org/writeups/shift/index.html
http://www.off-road.com/toyota/tech/shifter/index.html
http://www.brian894x4.com/Shifter.html
http://toyota.off-road.com/toyota/ar....jsp?id=186539
http://www.marlincrawler.com/docs/sh...eat/index.html
Old 07-22-2007, 04:06 PM
Kaydon's Avatar
Sounds like a plan, and from reading the links sounds like the problem. I'll get on that sometime this week.
Where would I be without YT?
Thanks guys.
Old 07-22-2007, 04:28 PM
Jay351's Avatar
I too recomend the shifter seat and shifter bushing.
It fixed all my shifter problems!
Old 07-22-2007, 04:38 PM
MMA_Alex's Avatar
pop the shifter out, and see how the bushing looks. its probably gone. Once you figure out whats up you can order the parts. The first time pulling mine was a pain, but once you figure out how to do it its easy to repeat
Old 03-14-2015, 07:00 AM
Wildgoose's Avatar
I know this is a real old post but my thanks to those on this forum who help out.
mwisham
05-26-2021 02:51 PM
punks_is_4x4
02-26-2016 04:29 PM
Davebarbier
11-03-2015 03:28 PM
hiluxinargentina
09-30-2015 11:12 PM
irv
09-22-2015 11:51 AM
Quick Reply: What? Loose shifter
