What is a intake air temp. sensor?? (3VZ-E)
Old 02-12-2008, 03:48 PM
Keener's Avatar
so the 4runner spit out a code 24 at me which says
"INTAKE AIR TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL"
i have got no idea what they are talking about, all i know is the VAF, TPS, and o2 sensors, but i think thats different stuff.
any help?
(oh ya, my main problem is just a lack of power all of a sudden one day. it idels fine, but as soon as soon as there is a load on the engine(driving), its just sluggish, my main suspect is air/fuel mixture, but so far i'm shooting blanks)
Old 02-12-2008, 03:54 PM
Matt16's Avatar
Your Mass Air Flow senses the temperature of the air coming in to the engine. Its the box with wires going in and out between the air filter and the throttle body.
As cold air is denser, more fuel needs to be injected to maintain the right air-to-fuel mix to burn cleanly and efficiently.
Beyond that, can't help you.
Old 02-12-2008, 03:55 PM
4runnerx3's Avatar
Most air temp sensors are in the air flow meter. It is used to compute the fuel ratio.
Old 02-12-2008, 04:03 PM
Matt16's Avatar
Does the engine feel any different on a colder vs warmer day? Calgary is a cold place.
Old 02-12-2008, 05:49 PM
Keener's Avatar
it does the same whether its warm or cold.
ya, i figured it was in the mass air flow sensor, so do i just need to clean it then?
Old 02-12-2008, 06:31 PM
toytech76's Avatar
You cant clean the 3.0 maf's. Yours you will need to replace
Old 02-13-2008, 05:40 AM
Keener's Avatar
so i need to replace the part that bolts on top of the air box right?
what about the plug/harness that plugs into it?
Old 06-12-2015, 07:24 PM
Graug's Avatar
Keener did you do the mafs and did it woke I have the same prb and it tosses the code 22 and 24
Old 06-13-2015, 01:29 AM
Fossilized
Staff
dropzone's Avatar
i can appreciate that you searched but good luck getting a response
Keener
Last Activity: 07-08-2011 07:19 PM
been awhile
Colington
03-08-2020 09:51 AM
Doug4320
03-24-2018 10:11 PM
RatOmeter
10-22-2015 03:17 PM
Alex Bessinger
08-31-2015 09:17 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: What is a intake air temp. sensor?? (3VZ-E)
