what is the green sensor next to the oil filter?
Old 08-22-2010, 05:28 AM
  #81
xalier's Avatar
ya i appreciate the info but the blancer hasnt slipped everytime i put it on tdc i can put a small screw driving in the plug hole and feel the piston is all the way up.. you can look in my pictures and see the keyway on the crank sticking straight up..
Old 08-28-2010, 08:08 AM
  #82
xalier's Avatar
anyone had any brain storming moments about my engine?
Old 08-29-2010, 06:08 PM
  #83
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Is the fuel pressure regulator hooked up correctly?
Old 08-29-2010, 06:52 PM
  #84
Exiledbikr's Avatar
Check you vaccumes i had this prob with one of my trucks, just one vaccume hooked up wrong caused mine not to start at all just back fire out the intake, and make sure your at tdc, cause theres the compression stroke and exhaust stroke.
Old 08-30-2010, 04:02 AM
  #85
1990yota-pickup's Avatar
did u ever check you ecu...
Old 11-28-2010, 08:43 AM
  #86
xalier's Avatar
sorry guys it pissed me off bad enough i just gave up on it and havn't touched it since. I had all my vacuum lines number matched to the holes so i wouldnt get any of them wrong. I know theres 2 differ strokes, and it blows my finger everytime i get near tdc so im sure im on the right stroke... Never checked the ecu.. Unsure of how i could really with out have a spare laying around. Any more ideas came into play while ive been letting it set on the back burner?
Old 12-06-2010, 12:23 PM
  #87
xalier's Avatar
anyone?
Eggslinger
06-08-2019 03:32 PM
jasonty
41
12-23-2018 01:00 PM
ryerye13
07-14-2015 08:27 AM
88yodabasket
07-13-2015 01:32 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: what is the green sensor next to the oil filter?
