what are a good brand for shocks
Old 03-26-2008, 04:16 PM
1992toyota4x4's Avatar
hey guys, on my 92 pickup im in need of some new front shocks, one is completely finished, im not sure if i have a lift on my truck or not, although with 31" tires it looks like it, i was just wondering what kind i should look into> i dont do any off roading, and this is my daily driver, and the roads here are lol.. i dont want to spent a load of money, just something that works well and looks good. thx
Old 03-26-2008, 04:44 PM
tacurt's Avatar
I put monroe reflex on my 87 4runner , they worked great for me. I drive 99% on paved roads. I just bought a set for my 94 also. Look on amazon.com.
Old 03-26-2008, 04:47 PM
Bear80's Avatar
How much is too much? For about $50 a shock I would put the Doetsch Pre-runner shocks up front with the MV-12 versions in the rear.
Old 03-26-2008, 05:17 PM
bRunner's Avatar
I put Tokico trekmaster shocks on my 4runner, waaay better than the monroe's that were on it cornering,braking, and pothole performance improved dramatically. I found a good price at carpartswholesale.com I have had good luck with them even though they didn't send all tha parts on the first order but it was cleared up and they shipped the remainder right away.
Old 03-26-2008, 05:37 PM
olharleyman's Avatar
Rancho has a buy 3 get one free lifetime warrenty deal going on right now
Old 03-26-2008, 06:07 PM
GenXr's Avatar
I run Bilsteins. They are good dependable shocks, excellent handling, but not cheap.
Old 03-26-2008, 06:13 PM
bigarms23's Avatar
skyjacker platnums are a good shock
Old 03-26-2008, 06:26 PM
crolison's Avatar
get some billys, thats what are going on mine when i lift her in may.
Old 03-26-2008, 06:50 PM
RobD's Avatar
Or Old Man Emu Nitrochargers. I have them on my 4Runner and rough roads don't upset the back end at all.
Old 03-26-2008, 07:04 PM
Matt16's Avatar
Beware of Pro Comps.
If you enjoy being beaten up, then Pro Comp ES3000s are for you. The ride is pretty rough on road. The shocks are WAY too stiff for the rear and ALOT too stiff for the front.
That said, they do a good job controlling the ride offroad as they really don't allow any bouncing around- which I really don't like off road.
Basically, if your truck is mostly off road, then Pro Comps are decent and cheap. If you dare to venture on a bumpy paved road, schedule a weekly back massage. You say you don't do any off roading, then go for Monroe Reflexes, Tokico Trekmasters- they are mostly on road shocks and ride well from everything I've read.
Old 03-26-2008, 07:24 PM
Jay351's Avatar
I like my pro comps Better then the old crap that was installed before. My truck rides better then alot of new suv's/trucks.
Old 03-26-2008, 07:29 PM
Matt16's Avatar
The "old crap" that was on there probably had been leaking fluid for the last decade or so. When I bought my truck last year, I took it to the dealer to check for recalls. There weren't any, but they had noted it was due for shocks back in 2000 as the one's on there were done D-O-N-E- back in 2000! Anything was better than the ride those gave.
I've ridden in Jay's truck and for hat ever reason, the rear doesn't "kick up" when the rear goes over a bump the same way mine does. Longer wheel base perhaps. Anyways, I personally don't like my P-C ES3000s
Old 03-26-2008, 08:54 PM
norcalsvx's Avatar
i like the bilstiens
Old 03-26-2008, 08:57 PM
Jay351's Avatar
I had checked over the old crap, didnt look like they had leaked anything. Just really worn out.
My truck is pretty smooth over bumps at speed. But its a truck, I never expected it to ride like a caddy!
as for the "kick" It might be the worn leafs
Old 03-26-2008, 09:25 PM
infiltrator's Avatar
Thanks for that info, I will have to check on that...
Old 03-26-2008, 09:29 PM
Dare44's Avatar
my OME nitrochargers are great i love them, stiffer than stock with a comfortable ride
Old 03-26-2008, 09:39 PM
904_runner's Avatar
I have an old pair of rancho 9000's (5 settings) on mine, at least one side on the front is shot (think from that fire i had) But other than that i like to be able to adjust the shocks! Handle great, soft if you want, stiff if you want.
But expensive.
Im going to highjack for a second because i have asked a couple times and no answer. What shocks are good for a 4" lift? (LC coils in rear) Also, do you know if i can use the stock length rear shocks up front after i put the lift on?
Thanks
Old 03-26-2008, 10:20 PM
dmorenoprieto's Avatar
I just bought a set of OME for $100. That's what all my friends run. Look on craigslist because there's always great deals on there.
good luck
Old 03-26-2008, 10:22 PM
Matt16's Avatar
All four for $100?! You just saved $300. Locker time!
Old 03-27-2008, 02:48 AM
cool im gonna look into all of your suggestions guys! appreaciate it!
young buck
18
08-27-2018 02:40 PM
A2theK
01-10-2016 10:18 AM
88sasturbotoy
08-11-2015 01:56 AM
akaphilly
07-09-2015 02:34 PM
Quick Reply: what are a good brand for shocks
