What gears do I have and what do I need to run 33's
Old 11-11-2008, 07:34 PM
redwingsfan008's Avatar
I have a '92 sr5 v6 5speed ex cab pickup and i know i can run 33x10.5's without a lift so i was wondering if my truck is gonna crawl to speed going downhill with the bigger tires or if my gears can handle it pretty well. i know it is the 3.slow and it already isn't a dragster but i would like to be able to pass on the highway or make it up a damn hill once in a while.
I guess the question is what gearing do i have now (i searched everywhere and can't find it) and will that be enough for 33x10.5's?
Old 11-11-2008, 07:59 PM
874runnersr5's Avatar
4.88's should do the job
Old 11-11-2008, 08:02 PM
904_runner's Avatar
Try it first. Im running 33x12.50's on stock gearing.
Im not sure what gearing you have now.
Old 11-11-2008, 08:03 PM
thanks, so i have 4.88's. that was the answer i found the most with all my research but i still wasn't for sure. they would be on stock alloys so the rims aren't super heavy either. which probably helps a little.
Old 11-11-2008, 08:16 PM
hmm you should be fine then.
i just went from 30" normal at tires, to 32" bf mudterrains, on a basic metal wheel.
I can already tell the difference.
Old 11-11-2008, 08:24 PM
i'll be going from 31x10.5at's to 33x10.5 at's I do quite a bit of highway so i am gonna stick with the at's. if it gets real sloppy i have chains but i have found bfg at's do pretty well.
if you are running 32x11.5's m/t's with a 22re and no re-gear i think i should be able to run 33's
Old 11-11-2008, 08:41 PM
yeah, if its highway driving you shouldn't have that much of a problem.
haha, well lets not say i dont need to regear...
im probley ordering my 4.88's tonight lol
Old 11-11-2008, 08:45 PM
thanks for the input
Old 11-11-2008, 08:52 PM
904_runner's Avatar
So its already been re-geared?
Old 11-12-2008, 06:49 AM
trbizwiz's Avatar
I am guessing with a 92 you more than likely have 4.30 gears, if you had an auto 4.56. now in 93 from what I understand, the 31 inch tires came with 4.56 with manual and 4.88 with auto, but there are many exceptions to that rule. I have a 92 and it is 3.0 with 5 speed and I had 4.30 gears stock. I put 4.56 on and the feel is much better with 31's, I will be going with 33 BFG's too, I am hoping that doesn't mess up my gearing too bad.
4.88 gears is the way to go with out question, if you decide to re gear. Re gearing will also give you the biggest perceivable power increase you can get with any mod.
Old 11-12-2008, 09:00 AM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
On the inside door jam, there is a stamped metal piece that tells you your vin, trim code,axle code, and all that info. And I think the 4x4wire site breaks down the axle code for you, telling you what gears came in axle, ring and pinion,etc.
Old 11-12-2008, 09:16 AM
CanTheWhales's Avatar
Check out the "Gearing" section.....: LINK
Old 11-19-2008, 06:46 PM
rbmoomba's Avatar
I have a 87 runner with stock 4:10 gears and a 22re with a 3" body lift and 33x 12.50"s. The motor is fresh with an engnbldr cam which holds rpms well and I can cruise all day long at 75mph with no problems. I am however in southeast texas so the horizon is just about FLAT, but it'll hold its own on bridges and such.
Old 11-19-2008, 09:08 PM
I jacked it up and spun the tires and counted revolutions. I spun the tire two full revolutions instead of one for accuracy, and found out I have 4.56 gearing. 4.88 would be better but i think new gears will come later. I make the 80 mile drive home from college about every two weeks and that is the majority of my driving besides trails on the weekend. I think stock will work well for now. thanks for all the input guys.
mskalmus
05-28-2017 07:51 AM
Jnkml
07-06-2015 01:20 PM
MTLroadierunner
07-06-2015 12:17 PM
wilbertd
07-06-2015 07:39 AM
karbin
07-05-2015 11:37 PM
Quick Reply: What gears do I have and what do I need to run 33's
