What is this dimmer switch from?
Old 08-19-2016, 06:11 PM
Amkalaskas's Avatar
This dimmer switch was in my 88 4runner. My dash lights don't work so I am guessing this isn't the correct dimmer. I bought the car used and I have finding a ton of bugs.
Attached Thumbnails What is this dimmer switch from?-1471658815942-1921663305.jpg   What is this dimmer switch from?-1471658857394-1763819806.jpg
Old 08-19-2016, 07:00 PM
RAD4Runner's Avatar
88 4Runner. 22Re? 3.0? Where is it connected to? Where on the truck did you find it? We could be thousands of miles away. Please help us see what you have right in front of you.
A problem well-stated is a problem almost solved.
Old 08-19-2016, 11:53 PM
wyoming9's Avatar
looks like the one from the Bed Room light I replaced
Old 08-20-2016, 03:17 AM
Amkalaskas's Avatar
I have the 22re. This is supposed to the dimmer switch for the dashboard. Mine is under the steering wheel it's located where the hole is.
QUOTE=RAD4Runner;52331730]88 4Runner. 22Re? 3.0? Where is it connected to? Where on the truck did you find it? We could be thousands of miles away. Please help us see what you have right in front of you.
A problem well-stated is a problem almost solved.[/QUOTE]
Old 08-20-2016, 05:59 AM
ThorInc's Avatar
Dash and console light dimmer....
Old 08-20-2016, 02:59 PM
RAD4Runner's Avatar
I do not remember what the variable resistor looks like in the back, but the knob looks stock.
Amkalaskas,
Yes, the dimmer mounts in that hole ^^^
I suggest you look behind it and see if the connector there mates with your variable resistor.
If it does:
1) We need to verify that wiring is stock based o schematic below, AND
2) We need to check if your variable resistor is good.
I hope you are comfortable using the multi-meter and reading the schematic here:
87truckdude
08-09-2016 09:10 PM
4runnerauto
07-04-2016 02:58 PM
Shooter1292
06-25-2016 11:06 AM
greyheadedguy
06-07-2016 12:16 AM
Bigwannas
06-01-2016 03:09 PM
Quick Reply: What is this dimmer switch from?
