What am I missing???
Old 01-24-2009, 04:20 PM
91Toyota's Avatar
Confused, what exactly am I missing? Here is the deal, I'm doing an auto to manual swap. As I've never really payed much attention to manuals, I know I am missing some basic stuff. Here is what I have.
Tranny, clutch kit (disc, pressure plate, release bearing, and pilot bearing), clutch fork, shifter, and slave cylinder.
Also, how the heck does the shifter stay seated? Am I supposed to remove that plate and slide the shifter under it?
As I can tell, I am missing a fork boot. Something on the splines on the shaft of the tranny for clutch operation. And a bracket on the side of the front of the tranny to support the slave.
Pics....
Old 01-24-2009, 04:42 PM
Staff
DeathCougar's Avatar
the shifter is supposed to have a locking ring on it that you press down and turn.
There is no such thing as a "slave cylinder support" it bolts straight to the bell housing.
Assuming you only have the throwout bearing, there is a bracket that the throwout bearing goes on, and two small clips that attach the clutch fork to the throwout bearing bracket.
Old 01-24-2009, 04:54 PM
91Toyota's Avatar
Guess I'll have to look for one. Don't think it'll work to well without one...i'll be driving down i-5 and I'll beat you with my shifter
You make it sound so obvious I see that now (the two holes on the far right side!)
There ya go! Thats what I was thinking. I saw it on my 2wd and fiddled with it trying to get it to go back on...and I noticed this one didn't have it. Where can I find one?
Thanks DC! Your the man!
Old 01-24-2009, 04:56 PM
Staff
Salvage yard? Or you could always get one from Toyota.
Old 01-24-2009, 05:11 PM
91Toyota's Avatar
And what is it called?
Old 01-24-2009, 07:23 PM
91Toyota's Avatar
No, truck was stolen and vin's were removed. The truck was given a "new" vin by the dmv and then riveted to the door jam.
Old 01-24-2009, 10:34 PM
Staff
no idea what its called, but it can't be too hard to describe to the dealer lol. Clutch throwout bearing bracket?
Old 01-24-2009, 10:40 PM
91Toyota's Avatar
It was hard enough explaining the "sleeve" on the output shaft on the transmission was.
I bet the first thing they ask for is a vin
Old 01-24-2009, 10:44 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Istn't the VIN stamped somewhere on the frame? It was on my old '91 Toyota longbed
Old 01-24-2009, 10:50 PM
91Toyota's Avatar
Yeah, I know exactly where its at on my 91...but is it the same all around (frame + cab = same?)
TheBFA
02-15-2020 06:55 AM
Badlander
10-10-2015 08:05 PM
voiddweller
10-02-2015 07:47 AM
hiluxinargentina
09-30-2015 05:51 PM
voiddweller
09-28-2015 11:21 PM
Quick Reply: What am I missing???
