webber carb?
Old 07-17-2011, 12:31 PM
87redyota's Avatar
webber carb?
i just ordered a cam from lce performance, got the stage 2 street cam and the full cam kit, sence i already have a header /full exhaust would a webber 32/36 carb be alright? also if i get a new carb should i get a new intake mani or can i just reuse the stocker?
Old 07-17-2011, 12:48 PM
xxxtreme22r's Avatar
you can reuse the stock manifold, the stage 2 came from LCE IMO would be a good match for the 32/36, but I would not have run that in a trail truck as it's a mid-high rpm cam. In a celica yeah, but a 4,000 lb truck that isn't gonna see 60+ in the desert, no.
Old 07-17-2011, 12:54 PM
87redyota's Avatar
according to LCE curve is 1500-5000, here in NY when were mudding we keep the t-case in 4low and the rpms high
Old 07-17-2011, 01:00 PM
not according to their website: http://www.toyotacatalog.net/M1WebGe...5-99A8D264DCBA
A Stage 2 cam will give you excellent mid-range power all the way up to around 6,000 RPM. The broad mid range this cam provides makes it an great upgrade for anything from a daily driver up to a rock crawler or even a mild race application.
And then goes on to say
20R/22R - Stage 2 Camshaft
4WD / Pre-Runner / Hot Street 2WD (1500-5500 rpm)
Modified Carb or Throttle Body & 1 1/2" Header
The stupid thing is, is how many rock crawlers do you know that spend most of their time at 4000 RPM ????? And 1500 RPM personally I don't feel is mid range rpm. Another reason other then misc stuff I refuse to order anything performance wise from LCE. Even their website gives conflicting info.
What really sealed it for me is the fact they told a guy on here that his weber was a fake because the jet kit they sent him didn't fit is manual choke DGV 32/36, when they simply just don't know weber's and the manual choke jets are different then the electric chokes. They probably told him that so he bought a "real" way overpriced weber from their site.
Old 07-17-2011, 01:29 PM
87redyota's Avatar
who else is a reputable parts maker for these 22r's? lce is the only one ive seen
Old 07-17-2011, 01:34 PM
engnbldr for heads and cams, thorley for headers, also NWOR for headers, trail-gear also makes headers theres lots out there. Putney's, many many others you just got to search most of which is on here. Weber kits, you can get them anywhere, I got mine at webercarbsdirect.com. Intakes there is a lot of offenhauser suppliers out there. Summit racing is one of them.
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
the_supernerd
10-01-2015 09:20 PM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
Toys4parts
09-26-2015 01:56 PM
taraf
09-25-2015 02:57 PM
Quick Reply: webber carb?
