W56 output shaft in an R150f...possible?
Old 04-28-2011, 11:45 AM
RBX
RBX's Avatar
I am about to aquire an R150f to swap out my A/T. I have a W56 with the attached RF1A t-case, the W56 needs a rebuild, and won't mate to the 3VZe anyhow.
I would like to get the gear driven RF1A transfer case mated to the R150 using an adapter, that part is easy.
HOWEVER, i understand that the W series output shafts are 21 spline and the R series are 23 spline. so to make this work i would need an additional $140 output shaft from a vender.
Is it possible to take the output shaft from the W56, and install it in the R150 to save a few bucks?
Any one try this?
Thanks
Old 04-28-2011, 12:32 PM
MSR
MSR's Avatar
no that is not possible however if you want you can cut the different couplers and weld them together not suggested though.
Old 04-28-2011, 12:37 PM
RMA
RMA's Avatar
inchworm has a 23 to 21 coupler .. if im understanding you correctly.
kawazx636
10-06-2021 03:03 PM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: W56 output shaft in an R150f...possible?
