VSV making vacuum leak noise when active (AC on), is this normal?
Old 01-02-2012, 08:32 PM
sinful's Avatar
I notice the shhh noise only when the VSV is doing it's cycle (AC on and RPMs up) when it opens and allows vacuum to circulate. When it shuts and RPMs drop, no noise.
Is the VSV leaking internally or is this normal?
thanks
Old 01-03-2012, 03:03 AM
alltracman78's Avatar
Sounds normal to me.
Valve open, allowing airflow, making airflow noise.
Valve closes, airflow stops, so does noise.
Old 01-04-2012, 05:14 AM
TNRabbit's Avatar
However, if one of the hoses to it has a hole, that could make more noise~
Old 01-04-2012, 10:26 AM
Sensei's Avatar
Typically you can't hear the vacuum flow through the 1/8" orifices in the valve. But, maybe you can in yours... check for a cracked hose. As long as the rpm isn't excessive for the a/c load you wont have any issues.
razorman8669
07-12-2015 12:13 PM
smiley52
07-11-2015 05:16 AM
nick b
07-11-2015 04:38 AM
Gamble_STi
07-07-2015 07:54 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: VSV making vacuum leak noise when active (AC on), is this normal?
