Vibration in the floorboard
Old 11-23-2009, 10:40 AM
nateW6777's Avatar
My 95 4runner has developed this nice massaging vibration in the floor board that consistently hmms up and down (more and less) as I drive. The wheels have been balanced in the near past, not sure if it could be my CV joints, unbalanced drive shaft, unbalanced tires?? any ideas??
Old 11-23-2009, 10:43 AM
IngSoc's Avatar
Have you removed and replaced your drive shaft lately? if so did you get the flanges lined up? Is your drive shaft dented any where? When you grab your drive shaft and wobble it a bit, does it have any play? Do you know the square root of 92837... If you said yes to any of these questions then your well on your way!
Old 11-23-2009, 02:50 PM
blue_CA_yota's Avatar
is the hum affected by engine speed, or road speed?
Old 11-23-2009, 04:19 PM
fresch's Avatar
Carrier/center Bearing on the two piece driveshaft?
Old 11-23-2009, 04:32 PM
wd21_sr5's Avatar
Bad/froze u-joint? Broken belt in a rear tire? Wheel falling off of a corner? Vivid imagination?
Old 12-01-2009, 11:04 AM
nateW6777's Avatar
The hum is present at any speed, although it increases in volume with rpms?? The U-joints seem ok and the tires are new and still on the truck. SOmeone mentioned a gasket or seal between the tranny and transfer case?? anyone familiar with this?
hiluxinargentina
09-30-2015 05:51 PM
JPV
09-28-2015 03:15 PM
Odin
09-26-2015 06:56 PM
4Xtruck
16
09-24-2015 09:38 AM
JustToynAround
08-19-2015 11:46 AM
Quick Reply: Vibration in the floorboard
