Very High pitched whine
Old 12-15-2008, 02:38 PM
86autoyota's Avatar
It's a very high pitched kinda whine/ring and it only happens when going between 40-55ish and when im on the gas. As soon as i let off it goes away.
any ideas?
Ive got a 86 pickup 22re
Old 12-15-2008, 03:25 PM
86autoyota's Avatar
bump-
Old 12-15-2008, 03:30 PM
AZ89LONGBED's Avatar
Rear pinion???
I had a similar problem in a CJ-5, it ended up being the rear differential was over-filled with fluid after servicing.
Old 12-15-2008, 03:35 PM
86autoyota's Avatar
that makes sense because i recently regeared and installed a locker, so you think that over-filling the diff would cause that noise?
Old 12-15-2008, 04:01 PM
Aye, that's what i'm sayin'... My noise showed up between 46-49 MPH, under acceleration only, similar to your problem...
Old 12-15-2008, 04:03 PM
86autoyota's Avatar
hmm interesting well thanks for some input!
Old 12-17-2008, 08:58 PM
Any luck??
Old 12-17-2008, 10:41 PM
Matt16's Avatar
How would you over fill the diff without it coming right back out the fill hole. You'd really need to stand the truck on end to over fill a diff, and if your truck is standing on end, you have bigger fish to fry than properly filling the diff
Old 12-17-2008, 10:43 PM
Matt16's Avatar
Where is this wine coming from, front or back. It is possible the backlash wasn't reset properly.
Old 12-18-2008, 08:28 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Matt16 has a very, very good point. Can't really overfill the diff....hehe.
Old 12-18-2008, 09:26 AM
TNRabbit's Avatar
I believe what you're hearing is my ex-wife in Tennessee....
Old 12-18-2008, 09:37 AM
swaycleveland's Avatar
i would say seeing as how you had a gear change you has something out of wack in there i would ask ZUK to help
Old 01-01-2009, 06:42 PM
Dude, my cj-5 (super-short wheelbase) had around 5-6 inches of lift, and the rear axle was setup spring over axle. I think I had around a 15-20 degree shim to realign my driveline angles, and it made it harder to fill the diff "full" because the drain plug was effectively lower.
Anyways, it invariably got over-filled by trying to squeeze more fluid in for fear of underfilling it. Then it made noise, and we took the diff cover off and rechecked everything, then refilled it with the exact amount specified, and it didn't make noise...
Anyways, what ever happened with your rear-diff noise 86auto?
Old 01-01-2009, 07:04 PM
space-junk's Avatar
welcome to my hell...
sounds like the same problem that i have... in talking with ZUK, sounds like my pinion bearing is shot...
prolly your problem too... im going to try to tighten up the pinion bearing pre load, and while its out, reset the carrier bearing preload as well...
hope that you got it fixed okay...
justdifferentials
14
06-11-2017 08:36 PM
Ktm526
10-07-2015 05:14 AM
Daenerysdad
10-01-2015 07:33 PM
potatopants
09-15-2015 06:26 AM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: Very High pitched whine
