vapor lock 3vze? desperate!!!!!
Old 07-16-2011, 06:56 PM
roelker87's Avatar
haveing problems with my 95 toyota 4runner. 3vze 5spd. the engine runs well. new rotor cap plugs wires fule pump &fillter. after running for about 30 mins or so when i shut it off it wont start again but will start back up again if i let the pressure off of the fuel line? any ideas
Old 07-16-2011, 07:57 PM
MudHippy's Avatar
FPU system malfunction.
Old 07-17-2011, 07:45 AM
roelker87's Avatar
Ill take a look in a few thanks
Old 07-17-2011, 01:20 PM
roelker87's Avatar
Anyone have any other ideas? Or where I could fid an vacume routing diagram to show me that I have the vacume lines ran correctly
Old 07-17-2011, 01:52 PM
xxxtreme22r's Avatar
vacuum diagram should be in the free downloadable FSM and also under you hood if your a lucky one and it survived. Also check autozone.com repair section.
Old 07-17-2011, 02:35 PM
MudHippy's Avatar
Old 07-17-2011, 02:55 PM
roelker87's Avatar
thanks alot for the diagram and asdvice will work on it tomarrow been working on it all day and am ready for it to be out site
Old 02-05-2012, 10:54 AM
Walshe8's Avatar
Mine is acting similarly. Will start after hot soak but after a few seconds it will big down and idle rough and low before dying. I bleed the fuel rail and it will run with no hesitation. I think my fuel cap is not bleeding excess pressure so the tank is under more pressure than the fuel rail so the pump won't supply fuel properly. Gonna leave the cap off and see if it helps.
westonian18
05-01-2020 06:38 AM
jasonty
41
12-23-2018 01:00 PM
A2theK
09-04-2015 03:16 PM
HaukurU
08-03-2015 02:40 PM
Sr5crawler
07-31-2015 12:32 PM
Quick Reply: vapor lock 3vze? desperate!!!!!
