Valve Body and o2 Sensor
Old 06-25-2009, 11:49 AM
sajidd's Avatar
Hi Guys
Just quick question on 1992 4Runner running 3 liter 3VZ E engine.
What is a valve body? what does it do? where can I buy it.
Same with O2 sensors.. what do they do? how many do I need? and where can I buy them?
Regards
Sajid
Old 06-25-2009, 12:03 PM
4Crawler's Avatar
No sure on the valve body, perhaps you mean throttle body? If so, it controls the flow of air into the engine. See the tech. articles bleow for more information:
- http://www.autoshop101.com/
O2 sensor measures the exhaust gas contents and helps control the fuel/air mixture. Usually need 1 or 2 of them:
- http://www.oxygensensors.com/
Old 06-25-2009, 12:10 PM
sajidd's Avatar
4Crawler: thanks for the quick reply.
You are right, its probably throttle body, because right now the shifting is very uneven in low range/ speeds.
by the way Is there something called gear valve body ?
Old 06-25-2009, 12:17 PM
4Crawler's Avatar
Might be referring to the hydraulic valve body on the transmission then. That is what controls some of the shifting functions:
- http://www.autoshop101.com/forms/AT01.pdf
Old 06-26-2009, 01:18 AM
sajidd's Avatar
4Crawler, i think you are right, hydraulic valve body is what i am probably what i am looking for.
And now to Google.. got to search and buy it.
Thanks for the help and the fantastic website reference.
Sajid
Old 06-26-2009, 01:36 AM
abecedarian's Avatar
What is the problem(s) with the transmission shifting?
Have you checked the fluid level and / or changed the fluid and filter?
Also, if the engine power is down for some reason, that can affect when and how the transmission shifts.
Old 06-26-2009, 01:59 AM
sajidd's Avatar
I think fluid levels are ok.
The problem in shifting is that it seems to shift unevenly or quickly, this happens when i am accelerate from stand still position. Once the speed is slightly over 10 to 15 miles per hour, the shifting seems normal.
Also in idle at times there is some kind of a very mild jerk.
Sajid
Old 06-26-2009, 02:06 AM
So it's a quick and hard shift from 1st to 2nd, but 2nd to 3rd and into overdrive are nice and smooth?
Old 06-26-2009, 12:21 PM
sajidd's Avatar
corect and today i floored it and it ran a bit at 6000 rpm before shifting up...
Old 06-27-2009, 12:30 PM
sajidd's Avatar
4CRAWLER: Any idea where i can buy the hydraulic valve body?
do you have its part #?
Rgards
Sajid
Old 06-27-2009, 12:32 PM
4Crawler's Avatar
No clue, never had an automatic. Try: http://www.toyotadiy.com/ or your local Toyota parts dealer.
Old 06-28-2009, 01:45 AM
sajidd's Avatar
Thanks..anyways..
Just one last question, is it called Hydraulic Valve body or Hydraulic Control unit or Throttle body....are these all the same things?
Old 06-28-2009, 07:02 AM
FredTJ's Avatar
Originally Posted by sajidd
Thanks..anyways..
It's simply called the valve body.
Is is highly unlike that the valve body requires replacement.
You need to take the vehicle to a transmission shop and have
them diagnose the problem. Could be line pressure. Could be
one of more of the shift solenoids. Could be the TV (kickdown)
cable requires adjustment. Could be a lot of things, but the valve
body itself being bad and requiring replacement is a very, very
low probability.
Fred
Old 06-28-2009, 07:44 AM
mt_goat's Avatar
low probability.
Fred
X2
Old 06-30-2009, 10:40 AM
sajidd's Avatar
low probability.
Fred
Fred, thanks for the info. Really helps!
Sajid
some drunk guy
08-03-2021 06:09 PM
shredder4286
10-01-2015 01:09 PM
charlie_fong
09-27-2015 10:06 PM
Boomer8404
09-24-2015 01:12 PM
sonorn67
09-19-2015 05:39 PM
Quick Reply: Valve Body and o2 Sensor
