V6 sputter and missing
Old 09-21-2009, 07:26 AM
kellhammer's Avatar
It a 1993 4runner with v6 replacement engine. When driving around 40 or 50, around 2000 rpm, I will back off the accelerator, then when i apply the gas the enging seems to sputter of miss. Like it's not firing or getting fuel. Other than that it drives fine. I thinking maybe vacuum leak that would adjust the timing?
Old 09-21-2009, 09:36 AM
sb5walker's Avatar
Check resistance of both VTA in the tps and VS in the air meter for a smooth change of resistance through the whole range of movement of throttle/vane. All values should be within spec and there should be no spikes or dropouts in resistance as you slowly open and close the throttle/vane.
Old 09-21-2009, 11:40 AM
kellhammer's Avatar
I will give that a try.
Old 01-22-2011, 05:38 PM
jjearl's Avatar
when i hit the gas from an idle mine sputters and its running rich overall. what should i check?
Marley2984
12-06-2015 05:19 AM
Firefightersink15
11-23-2015 10:32 PM
Sam hain
19
09-30-2015 08:25 AM
93RedKrawler
09-25-2015 04:03 AM
Gutted91
09-17-2015 05:44 PM
Quick Reply: V6 sputter and missing
