UnPlugging the O2
Old 09-01-2007, 08:56 AM
gametom's Avatar
UnPlugging the O2
ok so i have a 91 4runner with the 22re. i know the truck is running rich really rich like 16mpg rich, and my exhaust is crap full of rust holes. Which makes me think it's my o2 sensor sending the rich command consistently. So if i unplug the o2 sensor it should run on the factory determined amount of fuel. Now I plan to redo the exhaust in about 2 weeks and was wondering if anything bad could happen if i unplug the o2 until then to see if my mileage improves.
Old 09-01-2007, 08:58 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Is the CEL coming on?
Old 09-01-2007, 09:06 AM
gametom's Avatar
no cel yet
Old 09-01-2007, 09:09 AM
OSU4Runner's Avatar
You would probably have a CEL if the O2 sensor is bad....and unplugging it would probably throw a code as well. If your getting new exhaust in 2 weeks I'd just leave it, and deal with it a bit longer.
Old 09-01-2007, 10:42 AM
dezrik's Avatar
Taking the O2 sensor out will give you worse gas mileage, It took me over a month to trace my O2 sensor wire, the truck was run for awhile with no o2 sensor it clogged up the cat
Old 09-01-2007, 09:48 PM
longhungsilver's Avatar
Ya if u take the 02 out of the mix you will be worse off believe me
Old 09-02-2007, 08:40 AM
gametom's Avatar
my cat is crap to start with
Old 09-06-2007, 06:58 AM
OSU4Runner's Avatar
Your truck is going to run worse if you remove the O2 sensors.....regardless if the cat is already shot.
Old 09-06-2007, 07:46 AM
MMA_Alex's Avatar
without the o2 it should go into limp mode, and will bareley even be drivable.
with a number of exhaust holes it probably is running pretty rich. best bet is just to suck it up until you can get the exhaust replaced.
some drunk guy
08-03-2021 06:09 PM
tazman1972
11
09-28-2015 10:32 PM
Boomer8404
09-24-2015 01:12 PM
larrys93pickup
09-17-2015 07:05 PM
zz_denis
09-06-2015 03:43 PM
Quick Reply: UnPlugging the O2
