turn signals don't work - 88 4runner
Old 02-01-2010, 10:10 PM
chuntr's Avatar
well, I was moving my turn signals up into my side marker lights after putting on a new bumper, and I mixed up my hot and ground wires for the turn signal. all hell broke loose for a few seconds when I turned the signals on (brake lights started blinking, dash lights blinking) then obviously something blew because the turn signals don't work at all now. here's what I know:
- the hazard lights still work perfectly normal, turn signals don't.
- the bulbs are not burned out
- the flasher is fine. (I tested it in my other truck)
- I can't find a blown fuse anywhere
- the two breakers next to the fuse box/flasher have continuity so they seem fine.
any ideas? its got to be a fuse or something somewhere, but maybe I fried some other component when I shorted out the turn signal?
Old 02-01-2010, 10:16 PM
olharleyman's Avatar
pull your battery cable and reset everything see if that does anything may be a reset you can't find my did that once and thats how I fixed it
Old 02-02-2010, 12:47 AM
milehigheric's Avatar
Your hazards and turn signals have two different power sources but the bulbs share common grounds as well as all the wiring after the two switches. If your hazards work (the actual lights blink) then you can rule out grounds, and faulty wiring as they are common in both circuits.
Check your Turn fuse (10A), sometimes they look fine but are blown...It is in your kick panel. The only other component that could be the issue is your combination switch, but hopefully it is that pesky fuse.
Out of curiosity do your wipers still work? They receive power from the same source as the turn signals although are fused independently obviously.
Old 11-05-2016, 06:20 AM
sean43's Avatar
Signals don't work, intermittent wipers don't work, wiper sprayers don't work
I have a 1990 4Runner sr5, 3L, automatic. The turn signals, the intermittent wiper, and the wiper sprayers all do not work. My mechanic has narrowed it down to the combination signal/wiper assembly that goes in the steering column. My VIN calls for part number 84310-35400. This is the combo switch that does not have the rear wiper option. This part is discontinued, I can't find it anywhere. Part number 84310-35480 is the same part for the models with a rear wiper. My question is, will this part work, does it have the same wiring harness configuration? Could I get this part and not hook up the rear wiper part since there isn't one? If it is compatible, it would be a good modification because I could have the rear wiper wired and installed?
Old 11-05-2016, 09:22 AM
AKyotajunky's Avatar
Yes it will work. I am having weird turn signal problems in my 91 pickup so I stole the signal wiper assembly out of my 91 4Runner and though it did not fix my turn signal problem my wipers and squirters work fine. And now instead of the base model off, fast, and way to fast wiper positions I now have intermittent wipers 👍🏻 it's the small things in life
Old 11-06-2016, 04:26 PM
RAD4Runner's Avatar
Hi Sean43 and AKyotajunky,
I do not have a second-gen 4Runner but am wondering IF indeed the turn signal and the wiper switch assemblies are on one module because they're separate systems. Have you verified?
Old 11-07-2016, 01:10 PM
wyoming9's Avatar
Red face
Long day in the Salt mine looking quick at my 92 EWD they need to be different because the share no common plugs
Weather they can be changed I don`t know never had need to take things apart.
Physical damage to the combo switch or the harness connectors or wires ??
Old 11-11-2016, 10:28 PM
Yes they are
Old 11-13-2016, 07:42 AM
RAD4Runner's Avatar
OR we could narrow it down to either the +12V OR ground connection that is common to all three above.
I would not replace that part, yet.
Toyota components are bullet-proof. MOST OFTEN it is the way they are connected/assembled that cause problem.
IF someone could share schematic of the I have a 1990 4Runner sr5, 3L, automatic.. we can see.
gillesdetrail
11-19-2019 12:56 PM
Yota.Jay
03-06-2016 11:02 PM
shadowbirdie
06-24-2015 03:54 PM
gog1968
06-22-2015 05:55 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: turn signals don't work - 88 4runner
