Trying to drop manual transmission?
Old 07-13-2012, 07:53 AM
Roofmaster's Avatar
I have the engine out.3.0 came out yesterday.Im trying to drop the tranny,Ive unhooked everything I can see and am going to drop it out the bottom along with cross member and transfer case.I also removed the sway bar.I just removed the shifting knobs and am wondering if those long shift shafts also come off to little nubs,or do I remove the bolts around the base of the shift levers?I dont see any way to drop it with those shafts on.
Old 07-13-2012, 07:58 AM
SPARKS89's Avatar
Pull the boots off the shifters inside and remove the bolts. The shifters should lift right out. Don't try and fight the transmission from the bottom if those are still on the top. It'll be a pain.
Old 07-13-2012, 08:17 AM
racersg's Avatar
X2. Good advice. I leave the crossmember on also. Seems to be easier.
Old 07-13-2012, 08:47 AM
waskillywabbit's Avatar
Take the shifters off.
Cover up holes you leave in tranny/tcase. A bolt down there wouldn't be good.
:wabbit2:
Old 07-13-2012, 08:48 AM
motocrossaddict223's Avatar
the tranny goes in and out with the shifters out. I would reccomend if youre putting the motor back in, put the tranny and motor back in together. That way you can torque all the bolts down correctly etc.
Old 07-13-2012, 08:51 AM
Roofmaster's Avatar
Thanx guys
I'm in the truck now removing.bolts then all I gotta do is remove four bolts on crossmember and lower jack.These majic phones are great.Tpe while you work.Thanx again.
Old 07-13-2012, 08:55 AM
x2 what wabbit said, COVER those shifter holes!
Old 07-13-2012, 09:05 AM
Roofmaster's Avatar
Im working alone,best jack placement?
I'm doing this alone.Whare would the best placement for the floor jack be?The cross member doesn't look good because it seems to far back.Is there a balancing point?The middle doesn't look good cuz that transfer case looks heavy.Straps???
Old 07-13-2012, 09:11 AM
Hmm doing that with one floor jack will certainly be a challenge...i did it with a motorcycle jack. People that use floor jacks use two...you could try supporting the front with a jack stand and lowering the rear, then strap the tranny to the jack and "pull" from the front of the tranny. Also mine didnt fit under the frame rails....i had to jack up one side of the body and pull the tranny out.
Old 07-13-2012, 09:33 AM
Roofmaster's Avatar
I do have another floor jack in my shed.
I have a smaller floor jack I will go get,(annoying fifty foot walk)I'm not only doing this alone but the truck i solo its on my front lawn (that's how us white trash roll here in Carver Ma.) so once the weight of the tranny is on the jacks its gonna gig right in and be tough to move.No I don't have plywood its under my sons 78. Cobra musting supporting my four jackstands.Going to get the other jack.
Old 07-13-2012, 09:35 AM
I did my whole auto to manual swap by myself with a motorcycle jack, and two floor jacks and a jackstand....with two floor jacks, you'll have to be creative if you're by yourself.
Old 07-13-2012, 09:45 AM
Roofmaster's Avatar
Im not keeping this truck.
I'm just salvaging the m!otor,tranny and rea axle for backup.Then the ttucks outta hete.I drive my 95 4x4xtra cab 3.0 as my DD.Will that make it any easier knowing I can trash this truck in the removall process?
Old 07-13-2012, 09:50 AM
not really, the body of the truck never really gets in the way of the tranny. if you're feeling extra ballsy you could try to make some sort of a "sling" out of two ratchet straps to lower the tranny, then get like a furniture mover of even just like a pallet of wood or something the tranny will rest on and you can pull on. Just remember, be careful and never work under the tranny while its suspended!
Old 07-13-2012, 10:17 AM
Roofmaster's Avatar
Ok jacks are in place.Looks really shady.
I have the smaller floor jack up front with 6 2x6s between it and the tranny,otherwise it wouldn't reach.My much larger jack is under the cross member.My plan is to remove cross bolts slowly lower tranny as I'm pulling large jack back kinda toward driver rear wheel,using the smaller jack and blocks as a fulcrum and just let it tip over as I'm pulling the other one.I'm scared now.
Old 07-13-2012, 10:19 AM
PowerstrokeJoe's Avatar
If you aren't worried about tearing up the clutch you can put a jack under the back and slide the trans backwards and let the bellhousing rest on the sway bar. Then you can take and drop the rear to the ground and put the jack under the bell housing and take it out. If you take the transfer case off you can darn near pick the trans out without a jack. Last time I put the trans in my it took 45 minutes to get it all back together. Its really not too bad of a job.
Old 07-13-2012, 10:20 AM
SPARKS89's Avatar
You better tie some straps under that thing between the frame rails to catch it. It sounds like your transmission is about to fall.........
Old 07-13-2012, 10:22 AM
yea if youre not worried about tearing the tranny up, just put both jacks under it and pull it back some then just let it drop
Old 07-13-2012, 10:32 AM
Roofmaster's Avatar
I am worried abou tearing up tranny.
The engines alreadt out,did that yesterday,alone.I'm trying to save the tranny,I don't want to damage it.I think the sway bar will catch the front when the blocks tip over then I can jack that up and pull.
Old 07-13-2012, 10:35 AM
Yea id say your best bet is to just let the sway bar catch the tranny, then you should be able to manhandle it out. Goodluck!
Old 07-13-2012, 11:10 AM
Roofmaster's Avatar
Ok crossmember bolts are off.
Its balancing precariously on 2 jacks.Gonna let her down.
Quick Reply: Trying to drop manual transmission?
