Truck Horn / Train Horn Switch
Anyone do this conversion / add-on yet, I want to do one that does not require any drilling. Photos and or recommendations are welcomed.
add one of these http://www.otrattw.com/proddetail.php?prod=VVPZCMD-189 http://www.otrattw.com/proddetail.php?prod=VVPZCMD-589 to the cut out on the sides of the dash next to the steering wheel.
no, the rocker only is $5. thats just the cover if you already have that style switch.
from the site:
ROCKER ONLY- $5
This is just the top part of the switch and is purchased if you already have switches and need to either replace the existing rockers or have purchased switch bodies elsewhere.
V2D1AH0B -SPST OFF/ON(momentary)- $15
Standard GREEN upper LED that is independently wired.
Three terminal switch with no rear barriers. Use 1/4" female disconnects or VCH housing. (Packard terminals for the rear housing are sold separately)
V2D2U66B- SPST OFF/ON (MM) $16
Two incandescent lights.
Both lights are independently wired
10 terminal base. Use 1/4" female disconnects or VC1-01 housing (Packard terminal extra)
they aren't the cheapest for switches but they are good quality. i just put 2 in for my lights. just look around for a momentary rocker and you should find something.
from the site:
ROCKER ONLY- $5
from the site:
ROCKER ONLY- $5
from the site:
ROCKER ONLY- $5
But those are some clean switches and well worth the money IMO, thanks
I'm still searching for the horn setup, the lady said maybe we can find an old cool sounding horn, or maybe an exotic horn, digging is half the fun
alfonz33
9
11-16-2015 09:21 AM
