Truck Cap Options - Post Photos - Ideas
Old 04-25-2013, 05:50 AM
ingenuitor's Avatar
Originally Posted by ingenuitor
Here is something interesting info, stupid internet, if its online it must be true lol: REF: http://tomzizzo.hubpages.com/hub/Tip...d-camper-shell
From 1989 to 1994, the basic Toyota truck, referred to by some as the SR5, didn’t change much, except for the addition of a third brake light in 94, something I already talked about. Before 1989, the 1984 to 88 trucks, are essentially the same as the 1989 to 1994, as far as the bed is concerned, however some may have what is called a ‘Japanese’ bed, meaning the bed rails roll to the outside. Think of it like this, on literally any truck today, you can only access the underside of a bed rail from the inside of the bed, a ‘Japanese’ bed is only accessed from the outside. I will admit I don’t know much about what will fit these types of beds since by the time I started selling camper shells these trucks were fairly old and I rarely saw one come into the shop looking for a shell.
Quoting myself now, taken from a reply online, just in case anyone else needs the info: Any shell off a Toyota shortbed from 1984 to 1994 will be a perfect match for a 86 ext SR5, unless you have a standard cab and put an extended cab shell on it, the angle to the shell will rub the top of your cab. Any shell off a 1995 to 2004 Tacoma will also fit-the shell will be a bit taller than your cab. Shells off of the pre-ranger mazda (pre 1993) should also work. I don't think you'll have too much trouble finding something. Hope this helps!
Old 04-25-2013, 11:24 AM
ingenuitor's Avatar
Originally Posted by Co_94_PU
Same things fit just needs a different mount than the standard clamps probably no option but to drill the rail like on the older style beds which were all rolled to the outside. There is actually a currently active thread "what is this bed" or some similar title, it shows those beds.
Don't recall if you posted a more accurate location than just PA. But here is used one that outta fit, just your truck is the wrong color (Subtext: plenty of these on the local craigslist where ever you happen to be. And always at a steep discount.)
PS. live cargo in the camper shell is a big no no. Exhaust poisoning hazard. You'll want the grommet/gasket and need to run the climate control on exterior intake to pump fresh air out the back windows.
Yeah that cap if it works would be worth buying for sure, paint it, repair and move on? Thanks for the link, was only looking for caps, man I have not seen the camper shells name since the 80's, I keep forgetting this is an 80's truck.
Old 08-09-2022, 05:19 PM
NathanVogus's Avatar
Originally Posted by JohnnyCanuck
I like this because it has a kind of 4runner look:
Attachment 163303
I recently got the same topper for my 92’ extended cab but it doesn’t seem to fit as snug to the cab as yours. There’s quite a bit of gap, did you have to add anything to fill the gap on yours or did it just fit like that as is?
Old 08-09-2022, 06:08 PM
old87yota's Avatar
You might have got a topper for a regular cab. The Exra cab has much more of an angled slope for the rear compared to the regular cab.
lledwod
09-06-2016 07:33 AM
dirtrider0129
10
06-24-2015 12:24 PM
Mutinebullfrog
06-18-2015 01:36 PM
2wdtundra
06-17-2015 01:41 AM
Old Red 94
06-16-2015 08:32 PM
Quick Reply: Truck Cap Options - Post Photos - Ideas
