Tricks to changing fuel filter on 22re
Old 10-15-2007, 06:41 PM
Shoua's Avatar
If you need to know why I'm asking this, just check out my other thread here:
https://www.yotatech.com/forums/f100...k-pics-126647/
So I need to change my fuel filter. I know where it's located. My question is this: do you guys have any tricks to getting to it and changing it without removing everything around it? It doesn't look easy, but I have to do it. Truck is '91 with 22re and 4wd.
YodaPala's Avatar
Majic Wand. And Wizard Hat.
Old 10-15-2007, 06:47 PM
chroad's Avatar
Magic is pretty much right. I had procrastinated for a few years, and finally did it while I had the front end disassembled adding BJ spacers, new pads & rotors, differential, CV axles... you get the picture. Even with everything off, it was still a pain to get my hands in there, and my hands are not exceptionally big.
Old 10-15-2007, 06:49 PM
89silverpu's Avatar
take off wheel, unbolt access panel, and squeeze your hands in there and do your best, I just changed mine, I ended up just tightening the bolts back up untill I felt it was tight enough by hand, there's no way to get a torque wrench in there.
Old 10-15-2007, 06:51 PM
Shoua's Avatar
But I don't have a magic wand and a wizard hat...
Trumpfan's Avatar
what he said: 1st time I did it I removed my intake, what a pain.
Old 10-15-2007, 06:56 PM
89silverpu's Avatar
Off topic, but trumpfan, I really like your quote in your sig.
Old 10-15-2007, 07:07 PM
gametom's Avatar
i didn't think it was that bad it only took me about 25-30 min
Old 10-15-2007, 07:12 PM
Shoua's Avatar
I need to change it on the ground, it's the thing I need to get it running again. I wish I had access to a lift, but I can't, as it won't run without me changing the fuel filter!
Old 10-15-2007, 07:18 PM
InternetRoadkill's Avatar
I changed mine. It was easy. Of course, the body was off the frame at the time.
Old 10-15-2007, 07:21 PM
YodaPala's Avatar
dunno wut 2 tell u............Oh, yeah this sucks.
Old 10-15-2007, 07:32 PM
89silverpu's Avatar
a lift would not help at all...
Old 10-15-2007, 07:33 PM
Shoua's Avatar
Yeah, but at least I wouldn't need to be kneeling and fighting the fuel filter. Oh well, that's what I get for almost sinking my truck. I gotta do, sooner or later.
Old 10-15-2007, 07:48 PM
ToyotaGuru's Avatar
Post Air Ratchet
A strong 1/4" air ratchet with some extensions to get
it off the mount.
To get the fuel lines off a really long 1/2" ext to get
the front line off. The rear is a nice long box end like the craftsman
pro series.
Make sure you open the gas cap and take the lines off first.
Old 10-15-2007, 08:01 PM
n4ynu1010's Avatar
Geesh mine was a pain and its easy to get to hehe
Old 10-15-2007, 08:10 PM
YodaPala's Avatar
just yank off fuel inlet hose to filter and reverse the gunk out bakwerdz. see Recycling to save the planet.
Old 10-15-2007, 08:40 PM
YodaPala's Avatar
it'll be good garsh I'm soooo bored.
smthwsn357
05-01-2024 07:28 AM
jbv808
08-06-2021 04:47 PM
nick b
07-11-2015 04:38 AM
Huntingtruckcletus
07-08-2015 05:26 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Tricks to changing fuel filter on 22re
