transmission help
Old 11-25-2014, 11:31 AM
c0de_red1's Avatar
transmission help
i have a 1986 pickup base turbo model 4x4 with the 5 spd manual. it currently has a tranny out of an 87 pickup 4x4. what im not sure of is exactly what model it is. can some one tell me where i can find anything on it that would tell me what it is. as far as i know i think its a w56, but im not really sure and my syncro is starting to fall apart on me.
Old 11-25-2014, 11:37 AM
c0de_red1's Avatar
and also if any one knows what years of 5speed and t-cases will bolt onto the 22r block incase i can find a good used one at a decent price.
Old 11-25-2014, 12:22 PM
slimbobaggins's Avatar
Here you go
http://www.4x4wire.com/toyota/faq/parts/
Old 11-25-2014, 12:40 PM
c0de_red1's Avatar
well, so id have to take it off to see how many bolts my front seal retainer has to know if its either a g52, g54, or w56... since they are all usually found behind the 22r/re, does any one know if id be able to bolt either one on and still bolt on my t-case?
Old 11-25-2014, 02:34 PM
Whoops, the info isn't in that link... there's a way you can decode which one you have given the info on the tag affixed to the firewall in the engine bay. I don't have my truck in front of me so I can't look at it at the moment. I'll take a look tonight.
I know there's a difference between the shifters on the W and G trannys and respective t-cases... If I recall correctly, the G series transfer case shifts via a rod that runs through the tranny and into the transfer case. So if you're going to swap from G to W, I guess you'll have to get the mating transfer case to go with it. If I'm incorrect about this, I'm sure someone will chime in.
Old 11-26-2014, 05:41 PM
c0de_red1's Avatar
well both shift levers sit in line with each other but are removed separately. and yes once taking the t-case stick out it has 2 rods that run back into the t-case. so does that mean i have a g series? but i should be fine tho if i get a w56 tranny w/t-case and bolt it on?
Old 12-12-2014, 11:21 AM
Yeah sounds like a G series. I'm not sure if the W56 is a direct bolt in (ie if the mounting holes line up) or not. I've read somewhere that if you go to a W56 you have to clearance the floor a little bit. Dunno if that's true or not.
Btw, here's the link to the tag identification:
http://www.4crawler.com/4x4/ToyVIN.shtml
TheBFA
02-15-2020 06:55 AM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
Odin
09-26-2015 06:56 PM
toyotasaurus
09-24-2015 03:30 PM
briholt
09-20-2015 10:26 PM
Quick Reply: transmission help
