Transmission Fill plug
Old 08-15-2013, 05:07 PM
1994toyota's Avatar
Hello, I have a 94 toyota pickup with the 5 speed. Was just checking fluids and decided to check the trans fluid. Well 20 minutes later using vise grips the plug is out. Where can I find a new fill plug at? I just vise gripped the old one back in for now. The threads are ok but the head is not. Any info would help thanks.
Old 08-15-2013, 05:37 PM
rworegon's Avatar
Toyota dealer
Auto recycler
Local parts store possibly
Old 08-15-2013, 06:06 PM
SPARKS89's Avatar
Find one at a local junkyard. You have a W56 series transmission and I can't imagine they would change the plug size on those so you should have a wide range of years to work with in finding a replacement. A 15/16" socket should fit what you need.
A little tip for anyone that might need it. Always make sure you can take out the fill plug before removing the drain plug. It sucks to drain the gear oil out and then find out you can't refill it.
Old 08-15-2013, 06:22 PM
1994toyota's Avatar
Haha that would suck if you could not get the fill plug out if you already drained it. I will see if the local junk yard has a toyota.
smthwsn357
05-01-2024 07:28 AM
the1998sr5
15
07-14-2020 08:35 PM
Eggslinger
06-08-2019 03:32 PM
jjrbus
07-17-2015 07:06 AM
mengquis
07-13-2015 10:39 AM
Quick Reply: Transmission Fill plug
