Toyota Axle Swap on Mazda B2200
Old 11-21-2012, 08:28 PM
Digital Philosophy's Avatar
Sick of the terrible aftermarket support for mazda so I'm planning on swapping in a rear end from a 86-95 truck/4runner and throwing in a locker. trying to gather some info to make sure everything will work.
I'd like to come out with an axle that is spring under, 6 lug, with the toyota 8" diff.
Looking for the distance between the (toyota) rear leaf perches center to center.
From what I've gathered:
All 4x4s are SOA, 2wd is spring under
4x4s are 6 lug on 5.5
2wd are 5 lug
So does this mean I'm gonna have to grind off and weld on new leaf perches underneath a 4x4 axle to stay with 6 lug?
The v6 2wd axle sounds like a potential as it has the 8" diff but its 5 lug, are there 6 lug conversion kits available?
Old 11-21-2012, 08:37 PM
BigBluePile's Avatar
Depending on the axle length, 4wd vs 2wd, why not use the 2wd axle housing with 4wd axle shafts?
TrikeKid's Avatar
You'll probably have to weld new perches on since the angle and mount width working in your Mazda is doubtful to begin with. Just grab a 4x4 axle and do the swap.
Old 11-21-2012, 10:15 PM
westjohns yota's Avatar
seriously, and dont do a spring under, do it how toyota came with, spring over, factory toyota housing, just change the utput on your trans, alot easier.....
Old 11-22-2012, 05:43 AM
Spring over is gonna give me more lift than my ifs front can handle as far as I can tell. Isn't it usually around 4 - 5"?
Old 11-22-2012, 05:44 AM
Robert m's Avatar
new axle perches http://www.ruffstuffspecialties.com/...TOY-PERCH.html and if you use the coupon code DEARWIFE you get 17.5% off your order for black friday.
Hatch man
08-25-2021 12:54 PM
vasinvictor
01-20-2016 12:39 PM
RaginAsian91
07-27-2015 07:11 PM
Gravel Maker
Vendor Advertising
07-02-2015 12:57 PM
Ott47
06-26-2015 05:21 PM
Quick Reply: Toyota Axle Swap on Mazda B2200
