torsion bar removal question 86 4runner
Old 04-02-2012, 06:35 PM
nicksmith18vt's Avatar
I"m working on an OME lift and I have everything done except for the torsion bars. I started taking out the passenger side torsion bar tonight and I got it detached from the anchor arm and torque arm. The problem is that there isn't any room to pull it out from the front or the back. In the back the gas tank is in the way, and in the front the brake lines are in the way. It doesn't look like it will fit through any holes. Has anyone replaced their torsion bar in an 86 4runner? I thought that the lock nut and adjusting nut was supposed to be the only problem.
Old 04-02-2012, 07:04 PM
xxxtreme22r's Avatar
How does the FSM tell you to do it?
Old 12-09-2013, 10:36 AM
tailsgunner's Avatar
I have the FSM for a 93 T4R. It says to "remove the torsion bar"...no joke. No picture nothing. Basically loosen the bolt and slide out the t-bar.
For me, I have an auto, and I figured out that removing the bolt for the AFT cooler and let that hang down (do not disconnect the ATF hoses) and doing that gave me enough room to slide the bar out in a few minutes.
Avenged
07-09-2015 07:55 AM
Cplmike
07-08-2015 08:47 PM
ItsJustD
07-07-2015 07:49 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: torsion bar removal question 86 4runner
