Tips on removing rounded off tranny fill bolt
Old 07-13-2009, 10:13 PM
Tubbyfatty's Avatar
So I was planning on replacing my tranny fluid but it looks like the previous owner stripped off the bolt and I cant get a wrench on it, it just strips more. I can get a good grip with channel locks but it wont budge. Should I use a torch?
What else could i try? I already have a new bolt ($5 from toyota) So i dont care if i destroy this bolt. I just want it off. haha.
This is the fill bolt btw.
Old 07-13-2009, 11:00 PM
Elton's Avatar
have a nut welded on ?
Old 07-13-2009, 11:33 PM
gary96360's Avatar
Old 07-13-2009, 11:37 PM
Tubbyfatty's Avatar
I dont have a welder. what else could i try before i try that?
Old 07-13-2009, 11:38 PM
Elton's Avatar
any shop prob wont charge u much to have it done
Old 07-13-2009, 11:43 PM
gary96360's Avatar
um use the chanel locks and tap with a hammer?
Old 07-14-2009, 01:11 AM
Lysmachia's Avatar
Best bet, have a peice of 12" long by 1 or .5" wide tac welded to it to break it free. (As long asit can be reached that way) It works wonders that way for stripped bolts (Espcially diff drain plugs) and as another poster said any welding shop might charge ya $5 to do it, or post up tha you need a fellow YT'r near Hillsboro Or to help ya out!
Good luck! And next time.... Anti Seize!!!! (and a good quality bolt so it won;t strip as easily!
Old 07-14-2009, 02:39 AM
buckz6319's Avatar
I would cut a groove across the head of the bolt with a zip wheel or hack saw so you can put a thick heavy duty flat head screw driver in it to turn it if it is accessible enough to do that
Old 07-14-2009, 03:13 AM
Matt16's Avatar
Maybe vice grips if you can't find a welder.
Old 07-14-2009, 03:58 AM
Marc's Avatar
Pipe wrench with a cheater bar.
You could always fill it through the top.
Old 07-14-2009, 05:09 AM
BoostinChick's Avatar
http://www.irwin.com/irwin/consumer/...IrwinCat100511
Bolt extractor. Best investment I ever made.
Old 07-14-2009, 05:26 AM
GorgeRunner's Avatar
That bolt extractor kit looks like something worth having.
Old 07-14-2009, 05:34 AM
It is worth every penny. I have used it more than once and for me it has a 100% success rate of getting a bolt out.
Old 07-14-2009, 05:40 AM
I really like torches; but sometimes they are not practical. I'm going to check out those extractors.
Old 07-14-2009, 06:39 AM
Tubbyfatty's Avatar
Alright thanks for the tips, my friend has a welder, ive just got to wait a few days since he is out of wire.
Ill try the pipe wrench and tap the bolt with a hammer before i get the weldin. Ill let you all know how it goes haha.
Old 07-14-2009, 08:02 AM
Evil.Dingo's Avatar
IS it already empy, if so fill it throught the shifter assembly.
Old 07-14-2009, 08:44 AM
ZUK
ZUK's Avatar
I have taken off numerous over-tightened or rounded off bolts with "that just right chisel" and a love tap from a hammer.
Old 07-14-2009, 08:50 AM
yodathespian87's Avatar
Those bolt extractors are worth it. If you can't get it off with one of those then I don't know what would work. They have come in handy numerous times. Not that much either.
Old 07-14-2009, 09:38 AM
I agree and can attest to this (as I posted already).
Old 07-14-2009, 09:40 AM
Tubbyfatty's Avatar
No its not empty, i was smart for once and tried the fill bolt before the drain haha.
Quick Reply: Tips on removing rounded off tranny fill bolt
