Throw out bearing issue
Old 03-03-2013, 07:29 PM
Thegutted4's Avatar
I just finished rebuilding my w56 transmission and when i tried to remove the throw out bearing from its housing that has the two little tabs that hold it in the fork I broke one of the tabs off. I was wondering if anyone knows where to get a replacement because I cant find one anywhere. Just to further describe the part, it is a cast iron piece that fits into the release bearing and it has two tabs on it' Any help would be greatly appreciated
Old 03-03-2013, 08:22 PM
tfreezee's Avatar
New throw out bearing should come with the part that broke!!
Old 03-03-2013, 08:32 PM
Thegutted4's Avatar
I ordered a clutch kit and it didnt come with one. Ive gone to all the parts stores and none of them have it
Old 03-03-2013, 08:47 PM
Co_94_PU's Avatar
31232A CLIP, RELEASE BEARING HUB
That might help.
Old 03-03-2013, 09:00 PM
tfreezee's Avatar
It is a one piece unit and any parts store should be able to get you a throw out bearing without any hassle. I have a Centerforce dual friction pressure plate, disk, and throw out bearing all did come in a kit but you can order them separate. Low range off road has aisin clutch parts.
Old 03-03-2013, 09:21 PM
Thegutted4's Avatar
Is the part number you gave me the actual throwout hub or just the clip? Heres a pic of the piece that broke
Attached Thumbnails Throw out bearing issue-snapshot-4.jpg   Throw out bearing issue-snapshot-3.jpg   Throw out bearing issue-snapshot-5.jpg
Old 03-03-2013, 10:01 PM
Co_94_PU's Avatar
It's just the clip. That part is "31230 BEARING ASSY, CLUTCH RELEASE"
Parts diagram link for my 94. You can goto the root website and check for your model year, it should be the same part name but might have a different number.
Old 03-03-2013, 11:59 PM
Thegutted4's Avatar
Thanks for your help man. Just finished ordering it
bigjstang
08-25-2021 12:41 AM
09-04-2015 09:27 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
ksmudrunner99
07-21-2015 05:33 AM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: Throw out bearing issue
