Throttle body, IACV and a busted t-case (picture)
Old 06-24-2009, 11:37 AM
Junkers88's Avatar
Took the day off to get some work done on the house and the rig. The house work went well, the rig is another matter.
I pulled the access panel in the cab off to replace the gasket (RTV) on the top of the t-case since it's been leaking and after cleaning it up I found this.
The t-case is cracked in four places. The one in the picture is the worst, the other three are hair-lines. Now the t-case shifts out fine, never jumps out of gear, doesn't grind or make any strange noises and so far I have no issues. Do ya'll think it will be ok while I source another one???
I also pulled the throttle body to clean it out and take a look at the idle air control valve (IACV). The TB was filthy and so is the plenum. I sprayed both with TB cleaner and got them scrubbed but am concerned about some of the build up running through the motor on initial start up. Should I be worried?
The IACV was packed full of carbon and I'm hoping that by cleaning it out I'll get rid of a recent freaky idle issue.
I'll let you all know and thanks for any help.
Old 06-24-2009, 11:39 AM
scuba's Avatar
Wow what a bummer on the Tcase..
my thoughts are as long as it has fluid you should be fine..
Old 06-24-2009, 02:56 PM
waskillywabbit's Avatar
Toyota early model tcases are cheaply made and have lots of casting marks that appear to be cracks, especially inside. I doubt that is a crack...or doesn't appear to be one from that picture.
Old 06-24-2009, 03:18 PM
flashkl's Avatar
wabbit to the rescue!!
Old 06-24-2009, 03:36 PM
yoterr's Avatar
x2^^ if it doesent leak fluid, and you have no prior issues with the T-case it sounds fine, but if you want peace of mind you can source a cheap one and keep it on hand, maybe even rebuild it and put some crawler gears in it
Old 06-24-2009, 04:29 PM
iamsuperbleeder's Avatar
that's what I was thinking; dirty'ed up casting line
Old 06-24-2009, 04:57 PM
BigBluePile's Avatar
eh. Wheel it.
Old 06-24-2009, 05:51 PM
corax's Avatar
yeah, I really don't see anything in that pic, the "crack" is too straight of a line to actually be a fracture . . . it wouldn't make sense that it would crack in that spot anyway, given the gear arrangement and how the case is stressed under load
smthwsn357
05-01-2024 07:28 AM
montanatruck
02-26-2017 07:07 AM
jetpilot
08-15-2015 06:48 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: Throttle body, IACV and a busted t-case (picture)
