Tensioner Pulley Bearing Replacement
Old 01-19-2013, 12:47 PM
xylicon's Avatar
Post Tensioner Pulley Bearing Replacement
Before I started all this work I searched this forum for specifics as to which bearing I need, how its done, etc, but I could not get a straight answer. So here is how I replaced the bearing in my tensioner pulley
Stock bearing part no. NSK 6204DU
This is the pulley I am concerned with (old picture)
Pulley Removed
Old bearing on the left, new on the right
Closeup of the old stock bearing
New bearing installed
Old 01-20-2013, 02:20 PM
rustypigeon's Avatar
Did you need a hydralic press? I was able to press mine in using a large bench vise and a piece of pipe that was the diameter of the outer bearing surface.
Old 01-20-2013, 02:52 PM
xylicon's Avatar
I used a socket and a hammer to remove the bearing.
I tossed the new bearing in the freezer for about 20 minutes, then I applied heat to the pulley with a small propane torch. I fetched the bearing from the freezer and it dropped all the way into the pulley with zero effort.
bigjstang
08-25-2021 12:41 AM
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: Tensioner Pulley Bearing Replacement
