Temp guage bouncing around?
Old 07-12-2010, 12:59 AM
4runner316's Avatar
1990 4runner v6. I am used to my oil pressure guage moving around a bit while driving - but not my temp guage. Whats going on here? It pretty much bounces around between low and mid until it warms up - then it was stay at half way usually until I come to a stop, then it will drop all the way down again. How do I fix this? I definitely don't want to chance anything being as I live in Phoenix and I definitely need to be sure of my engine temp!
Thank you!
Old 07-12-2010, 05:48 AM
Wes94's Avatar
This was happening in my wifes car. It was just a loose connection at the sensor. Find your water temperature sensor and check the wires to it. On the 3.0 it is at the back of the engine (near the fire wall) under all the heater hoses. Could be a bad sensor or just covered in build up but sine the needle is bouncing when the vehicle is moving i bet its just a bad connection. maybe a wire rubbed through.
Old 07-12-2010, 05:59 AM
Wes94's Avatar
Here is what searching the forum turned up: https://www.yotatech.com/forums/f116...ats-me-180367/
Davebarbier
11-03-2015 03:28 PM
bradahman
10-01-2015 09:24 AM
Matthew Perez
09-28-2015 05:43 PM
83
09-27-2015 04:13 PM
rmill05
09-27-2015 01:43 PM
Quick Reply: Temp guage bouncing around?
